The Teardown is pretty much the same as other Samsung Slider phones
해당 분해도는 수리 안내서가 아닙니다. Samsung Intensity 수리는 저희 서비스 설명서를 사용하십시오.
Remove the 8 screw that hold the back cover down.
Carefully pry back piece off
Start at the bottom and work toward the top.
Carefully remove the main board
Make sure to not tear the microphone cable, pry it from the phone carefully
Remove the 4 screw the holds the slider to the phone assembly
one of the screws will be behind the hinge
Carefully pry slider assembly loose from display assembly
LCD comes out pretty easily
Pry it from the bottom and work up the sides to release it if stuck
The glass can be removed with a little heat from a heat gun or blow dryer
Pry it out from the outside edges working around carefully
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
미리보기
