주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Samsung Intensity 수리는 저희 서비스 설명서를 사용하십시오.
  1. Samsung Intensity Teardown, Samsung Intensity Teardown: 1 단계, 이미지 1/1
    • Remove the back cover and battery
  2. Samsung Intensity Teardown: 2 단계, 이미지 1/1
    • Remove the 8 screw that hold the back cover down.
    • Carefully pry back piece off
    • Start at the bottom and work toward the top.
  3. Samsung Intensity Teardown: 3 단계, 이미지 1/1
    • Use the ipod opening tool to disconnect the Connector
  4. Samsung Intensity Teardown: 4 단계, 이미지 1/2 Samsung Intensity Teardown: 4 단계, 이미지 2/2
    • Carefully remove the main board
    • Make sure to not tear the microphone cable, pry it from the phone carefully
  5. Samsung Intensity Teardown: 5 단계, 이미지 1/2 Samsung Intensity Teardown: 5 단계, 이미지 2/2
    • Remove the 6 screws
    • Pry to ribbon cable assembly loose from the slider
    • Its glued on the left and right side
  6. Samsung Intensity Teardown: 6 단계, 이미지 1/1
    • Remove the 4 screw the holds the slider to the phone assembly
    • one of the screws will be behind the hinge
    • Carefully pry slider assembly loose from display assembly
  7. Samsung Intensity Teardown: 7 단계, 이미지 1/3 Samsung Intensity Teardown: 7 단계, 이미지 2/3 Samsung Intensity Teardown: 7 단계, 이미지 3/3
    • Remove the tape and pop the connectors and pull all the ribbon cables loose
    • Carefully pry the speaker loose from the case.
  8. Samsung Intensity Teardown: 8 단계, 이미지 1/1
    • Carefully work the keyboard loose from the display assembly
    • There are a couple fragile clips that hold it in place
  9. Samsung Intensity Teardown: 9 단계, 이미지 1/2 Samsung Intensity Teardown: 9 단계, 이미지 2/2
    • LCD comes out pretty easily
    • Pry it from the bottom and work up the sides to release it if stuck
    • The glass can be removed with a little heat from a heat gun or blow dryer
    • Pry it out from the outside edges working around carefully
David
회원 가입일: 08/10/11
148 평판
안내서 1개 작성함
West Georgia Technology West Georgia Technology 회원
Business
1 회원
안내서 1개 작성하였습니다
댓글 한 개
This was so helpful! How can I show my gratitude to you for these helpful instructions?
teh_pwnerer22 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 4,680
