주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Samsung Jitterbug 수리는 저희 서비스 설명서를 사용하십시오.
  1. Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: 1 단계, 이미지 1/3 Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: 1 단계, 이미지 2/3 Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: 1 단계, 이미지 3/3
    • First remove the battery and rubber feet from base and under phone number inside.
    • Undo all six screws. Only the two under the battery will come out fully.
  2. Samsung Jitterbug Teardown: 2 단계, 이미지 1/2 Samsung Jitterbug Teardown: 2 단계, 이미지 2/2
    • Pop the six clips indicated in green and remove back. I removed the two on the sides first, but it was a huge pain to open the rest of the way. I suggest starting from the top four.
    • Blue is the connector to the screen and speaker board in the top of the phone.
    • Purple is the chip and orange is charging port.
    • The opposite side of the board (not pictured) has the microphone on it, it's a small black round bump on the bottom.
  3. Samsung Jitterbug Teardown: 3 단계, 이미지 1/3 Samsung Jitterbug Teardown: 3 단계, 이미지 2/3 Samsung Jitterbug Teardown: 3 단계, 이미지 3/3
    • Unhook screen connector and pop out board (just put a screwdriver under and pop).
    • Peel off button pad.
  4. Samsung Jitterbug Teardown: 4 단계, 이미지 1/3 Samsung Jitterbug Teardown: 4 단계, 이미지 2/3 Samsung Jitterbug Teardown: 4 단계, 이미지 3/3
    • Remove rubber front, then turn over.
    • Pop all five clips. Start at the top near the hinge and work down.
  5. Samsung Jitterbug Teardown: 5 단계, 이미지 1/3 Samsung Jitterbug Teardown: 5 단계, 이미지 2/3 Samsung Jitterbug Teardown: 5 단계, 이미지 3/3
    • Blue is main screen and mini screen board. Green is button and underneath is the main speaker. Purple is
    • Pop out all pieces. Be careful not to break the cabling connecting the outer bits to the board.
Kari Fox
회원 가입일: 06/24/13
125 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 2,101
