해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
소개
Removing the outer casing of the Samsung SCH-U340.
  1. The U340's outer casing is held in place through a combination of screws and tabs. The screws are hidden under plastic plugs, which will need to be removed.
    • The U340's outer casing is held in place through a combination of screws and tabs. The screws are hidden under plastic plugs, which will need to be removed.
  2. After these plugs are pulled out, remove the two screws located under them. These screws are very small, so be sure to keep them safe.
    • After these plugs are pulled out, remove the two screws located under them. These screws are very small, so be sure to keep them safe.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. The only thing keeping the top part of the casing on now are seven tabs--one large tab (marked in red) and six smaller tabs (marked in yellow). To remove the casing, first start by removing the big tab.
    • The only thing keeping the top part of the casing on now are seven tabs--one large tab (marked in red) and six smaller tabs (marked in yellow). To remove the casing, first start by removing the big tab.
  5. Now remove the smaller tabs, doing the tabs marked in red last. After the tabs have been removed, carefully peel the outer cover off completely.
    • Now remove the smaller tabs, doing the tabs marked in red last. After the tabs have been removed, carefully peel the outer cover off completely.
  6. Removing the bottom cover is a much simpler task. After removing the four screws marked in the picture, simply peel the back cover off.
    • Removing the bottom cover is a much simpler task. After removing the four screws marked in the picture, simply peel the back cover off.
Anish Sambamurthy
회원 가입일: 2010년 02월 11일
29 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 915
