주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Samsung SGH-X450 수리는 저희 서비스 설명서를 사용하십시오.
  1. Samsung SGH-X450 Teardown, Samsung SGH-X450 Teardown: 1 단계, 이미지 1/1
    • Take out the battery and SIM Card.
  2. Samsung SGH-X450 Teardown: 2 단계, 이미지 1/1
    • Remove these screws.
  3. Samsung SGH-X450 Teardown: 3 단계, 이미지 1/1
    • If the screws are removed, you can take the case of with your fingers or a small flathead screwdriver
  4. Samsung SGH-X450 Teardown: 4 단계, 이미지 1/1
    • Now you see the PCB
    • Agere TR09WQTEF2B Processor
    • Agere PSC2106 Power Management IC
    • Battery contacts and power supply connector
    • SIM Card Slot
    • Back-Up battery
    • Antenna connector
    • 2,5mm Headphone Jack
  5. Samsung SGH-X450 Teardown: 5 단계, 이미지 1/1
    • LCD Dispaly cable, you can release this connector with a small flathead screwdriver
    • Be careful here, You can break the flatcable!
  6. Samsung SGH-X450 Teardown: 6 단계, 이미지 1/2 Samsung SGH-X450 Teardown: 6 단계, 이미지 2/2
    • To take the LCD display out of the case, click the upper case open with a small flathead screwdriver or case opener. Under the two pads under the LCD Display are 2 screws.
    • Be also careful here, go not to far with the screwdriver so you can not damage the LCD display.
  7. Samsung SGH-X450 Teardown: 7 단계, 이미지 1/1
    • Now you see this.
    • If you want to remove the LCD display, lift the PCB of the LCD display up with a small flathead screwdriver.
  8. Samsung SGH-X450 Teardown: 8 단계, 이미지 1/1
    • Finished!
Bryan
회원 가입일: 10/27/12
707 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 1,791
