주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Scrabble Flash 수리는 저희 서비스 설명서를 사용하십시오.
  1. Scrabble Flash Teardown, Scrabble Flash Teardown: 1 단계, 이미지 1/2 Scrabble Flash Teardown, Scrabble Flash Teardown: 1 단계, 이미지 2/2
    • This is a small game but still surprisingly fun... but not enough to keep me from tearing it down!
  2. Scrabble Flash Teardown, Remove the Back: 2 단계, 이미지 1/1
    • This was held together by only one Phillips screw. So far so good.
    • Battery was a CR2032, which seems to be a common choice for this type/size of device
    • The speaker is in the bottom-right hand corner, with the reset switch above it.
  3. Scrabble Flash Teardown: 3 단계, 이미지 1/1
    • Two screws and a clip held the two halves of the case together, with two more keeping the speaker in place. Also, it looks like the only screws used in this device are Phillips! Great!
  4. Scrabble Flash Teardown, On to the Motherboard: 4 단계, 이미지 1/2 Scrabble Flash Teardown, On to the Motherboard: 4 단계, 이미지 2/2
    • On the back side of the motherboard, we see the battery contacts in the upper-left hand corner, and the four screws that hold the display to the front.
  5. Scrabble Flash Teardown, Display Removal: 5 단계, 이미지 1/3 Scrabble Flash Teardown, Display Removal: 5 단계, 이미지 2/3 Scrabble Flash Teardown, Display Removal: 5 단계, 이미지 3/3
    • After removing three of the screws, I found that the one holding down the bottom-left corner of the display was stripped, forcing me to cut and rotate the corner away.
    • After that however, it just dropped right off.
    • The display is just a simple black and white LCD.
  6. Scrabble Flash Teardown, Done!: 6 단계, 이미지 1/1
    • And here we are, all done!
Isaiah Payton
회원 가입일: 12/29/16
133 평판
안내서 1개 작성함
댓글 2개
Very cool, great teardown!!
Kevin Stuckey - 답글
Mine has a broken infrared thingy. Any idea how to/if it's fixable? I hope someone reads this :s
Yemir 2 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 33
전체 시간: 2,030
