주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. External Storage 수리는 저희 서비스 설명서를 사용하십시오.
  1. Seagate 3TB Expansion Desktop Drive Teardown, Seagate 3TB Expansion Desktop Drive Teardown: 1 단계, 이미지 1/1
    • Start at the plain end (the opposite side from the power jack) with the spudger. Carefully pry slightly up and away.
    • Once you have the end opened up, use the credit card to hold it open.
    • When you have the entire end separated, carefully pry the sides out and away along the adjoining two sides, working your way towards the end with the power jack. Save that end for last, it should lift away when you're done with the other sides.
  2. Seagate 3TB Expansion Desktop Drive Teardown: 2 단계, 이미지 1/3 Seagate 3TB Expansion Desktop Drive Teardown: 2 단계, 이미지 2/3 Seagate 3TB Expansion Desktop Drive Teardown: 2 단계, 이미지 3/3
    • Work around the drive, ends first then the sides to open it
    • This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart.
  3. Seagate 3TB Expansion Desktop Drive Teardown: 3 단계, 이미지 1/1
    • Gently pull the sides slightly and the drive will lift out
  4. Seagate 3TB Expansion Desktop Drive Teardown: 4 단계, 이미지 1/3 Seagate 3TB Expansion Desktop Drive Teardown: 4 단계, 이미지 2/3 Seagate 3TB Expansion Desktop Drive Teardown: 4 단계, 이미지 3/3
    • Pull the rubber screw covers off, these are mounted with a little glue and came off easily
    • Remove all four screws with the philips screwdriver
  5. Seagate 3TB Expansion Desktop Drive Teardown: 5 단계, 이미지 1/3 Seagate 3TB Expansion Desktop Drive Teardown: 5 단계, 이미지 2/3 Seagate 3TB Expansion Desktop Drive Teardown: 5 단계, 이미지 3/3
    • Slide drive out of metal caddy (do not lift)
    • You will now have a SATA Hard Drive and the caddy separate
  6. Seagate 3TB Expansion Desktop Drive Teardown: 6 단계, 이미지 1/3 Seagate 3TB Expansion Desktop Drive Teardown: 6 단계, 이미지 2/3 Seagate 3TB Expansion Desktop Drive Teardown: 6 단계, 이미지 3/3
    • From the bottom of the caddy there are two black screws
    • With the Philips screwdriver you can remove these
    • Pull the circuit board gently and evenly to remove it
Edd
회원 가입일: 04/08/13
535 평판
안내서 2개 작성하였습니다
댓글 3개
if i add a different adapter that doesnt require power, will the drive still work?
sulz - 답글
Does anyone know what to do if the Data port does not work ?
remus lungeanu - 답글
Thanks... I probably broke every clip in the process, but I finally got it apart... Tested the drive in another external USB case and still can't see the drive, so my hope that it was the case circuitry that was bad was crushed... 3TB paperweight... Thanks Seagate :(
Sean Seoltoir - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 19
30일 전: 90
전체 시간: 55,194
