주요 콘텐츠로 건너뛰기
소개
Complete teardown of Sidekick II
해당 분해도는 수리 안내서가 아닙니다. Sidekick II 수리는 저희 서비스 설명서를 사용하십시오.
  1. Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
    • Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Remove screen from casing. Remove screen from casing.
    • Remove screen from casing.
  7. Remove 4 screws from back of screen using Torx 6 Screwdriver. Pry screen out of casing using fingers.
    • Remove 4 screws from back of screen using Torx 6 Screwdriver.
    • Pry screen out of casing using fingers.
  8. Remove 4 screws from front of screen with Phillip screwdrivers. Peel off the metal covering on the back of the screen. Be careful when taking off the metal covering. The orange ribbon will not come out all the way, and it is fragile.
    • Remove 4 screws from front of screen with Phillip screwdrivers.
    • Peel off the metal covering on the back of the screen.
    • Be careful when taking off the metal covering. The orange ribbon will not come out all the way, and it is fragile.
  9. Remove the protective cover in front of the screen.
    • Remove the protective cover in front of the screen.
    • Do not use metal tools, you may damage the protective cover or the screen. Use your fingers only.
  10. Take the screws out using the Torx 6 screwdriver. Then lift the thumb wheel and housing off of the front panel.
    • Take the screws out using the Torx 6 screwdriver.
    • Then lift the thumb wheel and housing off of the front panel.
  11. Remove 2 black "rivets" from back of casing with the plastic opening tool. Press keyboard out of front of casing using thumbs.  Don't press too hard as you may break the board.
    • Remove 2 black "rivets" from back of casing with the plastic opening tool.
    • Press keyboard out of front of casing using thumbs. Don't press too hard as you may break the board.
  12. Remove the 5 black screws with a Phillips head screwdriver. Lift the bottom of the control board from housing, and separate the two.
    • Remove the 5 black screws with a Phillips head screwdriver.
    • Lift the bottom of the control board from housing, and separate the two.
  13. Carefully remove battery and back plate.
    • Carefully remove battery and back plate.
    • Do not use metal tools, you may damage the control board. Use only your fingers.
  14. Here are all of the pieces that you have disassembled
    • Here are all of the pieces that you have disassembled
michael albaum
회원 가입일: 2010년 01월 20일
45 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010 회원
CPSU-MANESS-W10S3G19
4 회원들
안내서 11개 작성하였습니다
nice job from a former geek
Jared Boies - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 6,498
