주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
해당 분해도에 사용된 도구
소개
This is my first Teardown! Please don’t be negative about it. But, Constructive Criticism is welcome.
해당 분해도는 수리 안내서가 아닙니다. Sony Audio System RM-S100 Remote 수리는 저희 서비스 설명서를 사용하십시오.
  1. On the back of the remote there will be a battery cover. Open it up. On the back of the remote there will be a battery cover. Open it up.
    • On the back of the remote there will be a battery cover. Open it up.
  2. See the little tab? Don't break the tab when you open it. That will make it un-close-able! Use your Spudger to open it up
    • See the little tab?
    • Don't break the tab when you open it. That will make it un-close-able!
    • Use your Spudger to open it up
    • Don’t snap your Spudger!
    • This is so incredibly hard to open. I recommend also using a 3.5mm Flat Head so you don’t snap your Spudger.
    • Voila! (Whatever that means...) Its open!
    • This is very hard to open without breaking the tab or your Spudger. The repairability score will take a hit.
  3. Let’s start by removing the red thing. You can remove it with your fingers. Now pull out the PCB. (It is best to pull by the springs.)
    • Let’s start by removing the red thing.
    • You can remove it with your fingers.
    • Now pull out the PCB. (It is best to pull by the springs.)
  4. Pull out the button pad. Now, pull out the spring.
    • Pull out the button pad.
    • Now, pull out the spring.
    • And thats it!
  5. A total of 7 parts. (I was expecting more.)
    • A total of 7 parts. (I was expecting more.)
    • I would give this a repairability score of 8 out of 10.
    • I almost Broke by Spudger =(
    • Insanely hard to open.
    • Easy to disassemble... once open.
    • No screws. (No Screws to lose! No need remember which screw goes where.)
    • Easy to assemble...unless the tab was broken.
Aiden
회원 가입일: 2015년 09월 19일
14,813 평판
안내서 20개 작성하였습니다
This is a great first teardown! =) Keep it up!
Sam Goldheart - 답글
Thanks! I would do more but I don’t have much junk to disassemble that I don’t need.
Aiden -
Hi @captainsnowball ,
FYI
voilà French exclamation - meaning “There it is!” or “There you are!”
The “red thing” in Step 3 is most probably an IR filter, to filter out visible light to improve IR operation
jayeff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 30
전체 시간: 2,327
