주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Sony D-822K Car Discman 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sony D-822K Car Discman Teardown, Sony D-822K Car Discman Teardown: 1 단계, 이미지 1/1
    • Obtain a D822-K Discman and remote. True, it has DSP and Surround Sound, but the 90's have come and gone. It's okay to take it apart.
  2. Sony D-822K Car Discman Teardown: 2 단계, 이미지 1/1
    • Position unit so that the bottom is facing up. Remove the 6 screws.
    • Hold top and bottom of unit together as you turn the unit over, bottom facing down. Use caution; the upper and lower case, along with circuit board are now loose.
    • Watch out for the AVLS and illumination switches, they love to disappear when unsupervised. Remove top of case.
  3. Sony D-822K Car Discman Teardown: 3 단계, 이미지 1/3 Sony D-822K Car Discman Teardown: 3 단계, 이미지 2/3 Sony D-822K Car Discman Teardown: 3 단계, 이미지 3/3
    • Removing the CD reader: Gently pull all 3 rubber grommets sideways, away from the CD reader.
    • Slide edge of ribbon cable connector towards ribbon cable to disengage.
    • Unplug the red, white, and blue plugs from the circuit board.
  4. Sony D-822K Car Discman Teardown: 4 단계, 이미지 1/2 Sony D-822K Car Discman Teardown: 4 단계, 이미지 2/2
    • Observation: This is the Hydro Suspension system...really.
  5. Sony D-822K Car Discman Teardown: 5 단계, 이미지 1/3 Sony D-822K Car Discman Teardown: 5 단계, 이미지 2/3 Sony D-822K Car Discman Teardown: 5 단계, 이미지 3/3
    • Remove circuit board
    • Notice the dual-color light modules. (I temporarily connected the power to show off the lights)
  6. Sony D-822K Car Discman Teardown: 6 단계, 이미지 1/1
    • Disconnect tailpiece, and power supply.
  7. Sony D-822K Car Discman Teardown: 7 단계, 이미지 1/2 Sony D-822K Car Discman Teardown: 7 단계, 이미지 2/2
    • Remote: Remove the 3 screws from the bottom. Pull apart.
    • The function buttons have a neat overlay design.
  8. Sony D-822K Car Discman Teardown: 8 단계, 이미지 1/1
    • Completely disassembled. The illumination button was lost for two weeks after reassembling... but who uses amber lights anymore?
modem21
회원 가입일: 10/09/09
84 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 22
전체 시간: 18,057
