주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Sony DVD Player 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sony DVD VHS Player  Teardown, Sony DVD VHS Player  Teardown: 1 단계, 이미지 1/2 Sony DVD VHS Player  Teardown, Sony DVD VHS Player  Teardown: 1 단계, 이미지 2/2
    • This is the device we will be tearing down.
  2. Sony DVD VHS Player  Teardown: 2 단계, 이미지 1/1
    • First, you need to remove the three black screws on the back.
  3. Sony DVD VHS Player  Teardown: 3 단계, 이미지 1/1
    • Now, you need to remove the cover by lifting it up like you would the cover of a shoe box, but it will come off. But before you do that you will need to unhook it by unclipping the clips on the back.
  4. Sony DVD VHS Player  Teardown: 4 단계, 이미지 1/1
    • You must now remove the silver bar attached to the VHS receptor.
  5. Sony DVD VHS Player  Teardown: 5 단계, 이미지 1/1
    • Once you have removed that silver bar you will now unscrew and remove the DVD Disc tray.
  6. Sony DVD VHS Player  Teardown: 6 단계, 이미지 1/2 Sony DVD VHS Player  Teardown: 6 단계, 이미지 2/2
    • Now that the DVD tray is out of the way, you can remove the smaller motherboard, the green one to specify easier. You will do this by removing the screws that hold it in.
  7. Sony DVD VHS Player  Teardown: 7 단계, 이미지 1/3 Sony DVD VHS Player  Teardown: 7 단계, 이미지 2/3 Sony DVD VHS Player  Teardown: 7 단계, 이미지 3/3
    • Now you can unscrew the VHS receptor and remove that to be able to access, unscrew and remove the final piece, the large motherboard.
  8. Sony DVD VHS Player  Teardown: 8 단계, 이미지 1/3 Sony DVD VHS Player  Teardown: 8 단계, 이미지 2/3 Sony DVD VHS Player  Teardown: 8 단계, 이미지 3/3
    • Now, you will remove the large, orange motherboard. You will need to unscrew it and pop it out. You MUST be careful as this piece is extremely fragile, and the smallest fracture or damage will cause it to no longer work.
Blake Sullivan
회원 가입일: 04/20/18
185 평판
안내서 1개 작성함
댓글 한 개
Wish I could repair the DVD no luck in finding part the part
Joseph Pigott - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 2,335
