해당 분해도에 사용된 도구
소개
I will teach you how to deconstruct a DVD-ROM unit into it's base assembly and then show what many people use to build a burning laser.
Remove outside screws using a screwdriver that fits a M3x6 screw
To remove the pole that was in the picture before it was removed, push down on the spring with a screw at one end removed the tilt one end up and remove
To remove toothed gears push the clip inside the spire in the middle of the gear, and maintaining pressure on the clip pull away the gear
Apply the same technique as in picture 2 but with the clip in picture 3
