주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Sony Dream Machine ICF-C211 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sony Dream Machine ICF-C211 Teardown, Sony Dream Machine ICF-C211 Teardown: 1 단계, 이미지 1/3 Sony Dream Machine ICF-C211 Teardown, Sony Dream Machine ICF-C211 Teardown: 1 단계, 이미지 2/3 Sony Dream Machine ICF-C211 Teardown, Sony Dream Machine ICF-C211 Teardown: 1 단계, 이미지 3/3
    • How many of you at least once in your life wanted to smash your alarm clock against the wall to make it stop beeping?? Well today we're gonna do something worse... we're going to tear it down!!
  2. Sony Dream Machine ICF-C211 Teardown: 2 단계, 이미지 1/2 Sony Dream Machine ICF-C211 Teardown: 2 단계, 이미지 2/2
    • Let's turn the alarm clock upside down, regardless of the risk of electric shock as stated by the caution sign, we proceed using a regular Phillips screwdriver.
    • As you can see the Sony Dream Machine has a battery power backup just to make sure it'll ruin your dreams by going off even if the power is out! Diabolical..
  3. Sony Dream Machine ICF-C211 Teardown: 3 단계, 이미지 1/3 Sony Dream Machine ICF-C211 Teardown: 3 단계, 이미지 2/3 Sony Dream Machine ICF-C211 Teardown: 3 단계, 이미지 3/3
    • After removing the screws, lift the front clear plastic panel in front of the LED.
    • Now flip the alarm clock. Lift the top gently to avoid breaking any plastic component inside, because you won't find any screws inside, everything is locked with plastic joints and glue...interesting..
  4. Sony Dream Machine ICF-C211 Teardown: 4 단계, 이미지 1/3 Sony Dream Machine ICF-C211 Teardown: 4 단계, 이미지 2/3 Sony Dream Machine ICF-C211 Teardown: 4 단계, 이미지 3/3
    • Here it is.. your alarm clock split in half.
    • Now we need to remove the circuit board... nothing easier... just lift it from the side with your thumb and there you go!
    • Before we move on to the top half of the alarm clock we need to remove the AC, just like the circuit board use your thumb for some leverage and it will easily pop out of its case.
    Saludos, cual es el voltaje de las dos salidas del transformador?
    Giovanni Colmenarez - 답글
    Please Help.i need data of transformers pin 1 2 3 4. send ur replay to agusalternative@gmail.com thanks
    agusalternative - 답글
  5. Sony Dream Machine ICF-C211 Teardown: 5 단계, 이미지 1/1
    • This is probably the most fun part of the teardown: manage to unglue the speaker off the case... I suggest you grab a flathead screwdriver and start digging.. just be careful not to damage too much the plastic ring around it or you won't be able to put it back on!
  6. Sony Dream Machine ICF-C211 Teardown: 6 단계, 이미지 1/2 Sony Dream Machine ICF-C211 Teardown: 6 단계, 이미지 2/2
    • Here are some pictures of the circuit board.
    • Our teardown is now complete!! Good luck putting it back together!
matte18
회원 가입일: 10/12/09
405 평판
안내서 2개 작성하였습니다
댓글 2개
does any1 know how to increase brightness in this clock? the manual says nothing and the display has dimmed tremendously!
econtit - 답글
Mi power backup for clock no enciende don’t turn on what can I do ??
Rafa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 45
전체 시간: 19,302
