주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Sony Ericsson K750i 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sony Ericsson K750i Teardown, Battery Cover: 1 단계, 이미지 1/1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i Teardown, Back Casing: 2 단계, 이미지 1/1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i Teardown: 3 단계, 이미지 1/1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i Teardown: 4 단계, 이미지 1/1
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i Teardown, Keypad: 5 단계, 이미지 1/1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i Teardown: 6 단계, 이미지 1/1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i Teardown: 7 단계, 이미지 1/2 Sony Ericsson K750i Teardown: 7 단계, 이미지 2/2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i Teardown, LCD Screen: 8 단계, 이미지 1/1
    • Remove the screws holding the screen in place.
  9. Sony Ericsson K750i Teardown: 9 단계, 이미지 1/1
    • Gently lift the base of the keypad to remove it.
  10. Sony Ericsson K750i Teardown: 10 단계, 이미지 1/1
    • Gently pull up the green film, avoiding the joystick.
    • The LCD screen will be attached to this film and come off with it.
  11. Sony Ericsson K750i Teardown, Sony Ericsson K750i Teardown: 11 단계, 이미지 1/1
    • Remove the back cover from the phone.
    • Gently slide the ribbon out of its connection.
  12. Sony Ericsson K750i Teardown: 12 단계, 이미지 1/2 Sony Ericsson K750i Teardown: 12 단계, 이미지 2/2
    • Lift the motherboard out of the phone.
    • The ribbon is fragile so work the motherboard off around the ribbon to prevent damage.
  13. Sony Ericsson K750i Teardown: 13 단계, 이미지 1/2 Sony Ericsson K750i Teardown: 13 단계, 이미지 2/2
    • Pry off the microchip that is located below the ribbon.
  14. Sony Ericsson K750i Teardown: 14 단계, 이미지 1/2 Sony Ericsson K750i Teardown: 14 단계, 이미지 2/2
    • Lift out the plastic support to complete the teardown.
Abby Evers
회원 가입일: 10/04/11
202 평판
안내서 6개 작성하였습니다
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G6
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 23
전체 시간: 12,421
