소개
My Vaio FZ recently got hot and its fan was working loud. I decided to tear it down and remove the 2-year-old dust:)
필요한 것
Now the tricky part. We need to remove the speakers/additional control keys cover.
To do so, we need to lever the 3 pins in the battery bay (marked red). Do it gently not to brake them.
You may want to lever the marked blue pins accessible from the DVD bay, just nest to the side.
Now pull the cover.
The rest of the pins (marked yellow) will go out as you will gently pull the cover.
댓글 4개
My FZ19VN was also getting hot though the fan didn't seem to be labouring, so I decided to do the same. In fact there wasn't much dust on the fan or the heat exchanger but what I did notice, surprisingly, was that unlike yours it only has the one heat pipe taking heat from the CPU. The other white metal heat sink is left to cool itself, which is why the base of the laptop gets very hot! Otherwise the case and motherboard seem to be virtually identical to yours.
I see yours is FZ21Z (model PCG-391M) - evidently a higher spec requiring more cooling than my FZ19VN (model PCG383M).
I removed the screen entirely, and now?
the two hinges are in differing positions?
one will fit into the space it left
the left hand side is waay out of alignment
what happened and how do i get it to the same position?
i notice theres a nut on the end of the hinge fitting
loosen that maybe?
its a friends pc
i have to sort this;-(
heelp;-(
