주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Sony Walkman WM-4 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: 1 단계, 이미지 1/2 Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: 1 단계, 이미지 2/2
    • Flip the Sony Walkman so that its rear side faces you.
    • Use a screwdriver to remove the two screws from the surface of the Walkman.
    • Press the battery plate slightly with your thumb and slide it downwards. This will open the battery compartment.
    • Remove the batteries from the Walkman.
  2. Sony Walkman WM-4 Teardown: 2 단계, 이미지 1/2 Sony Walkman WM-4 Teardown: 2 단계, 이미지 2/2
    • Turn over your Walkman and gently press the cover to open the cassette holder.
    • When the cassette holder is opened, you can see two more screws.
    • Using a screwdriver, remove the two screws.
  3. Sony Walkman WM-4 Teardown: 3 단계, 이미지 1/2 Sony Walkman WM-4 Teardown: 3 단계, 이미지 2/2
    • Use a plastic opening tool or a spudger to push the tabs. This will remove the cover and open the Walkman.
    • Be careful so you dont break the tabs!
    • Once the Walkman is opened, you can troubleshoot for any issues, remove the old wires and attach new ones, or even reassemble the Walkman.
lenzo
회원 가입일: 07/14/11
125 평판
안내서 1개 작성함
댓글 한 개
Drive belt trashed any ideas where to get one?
nz-tiger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 34
전체 시간: 15,913
