주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Sony Xperia Z3 Dual 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sony Xperia Z3 Dual Teardown, Sony Xperia Z3 Dual Teardown: 1 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown, Sony Xperia Z3 Dual Teardown: 1 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown, Sony Xperia Z3 Dual Teardown: 1 단계, 이미지 3/3
    • Remove two SIM card trays.
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and to open a gap from top side.
  2. Sony Xperia Z3 Dual Teardown: 2 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown: 2 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown: 2 단계, 이미지 3/3
    • Insert the guitar pick into the opening gap.
    • Slide the guitar pick to cut the adhesive sticker. Attention: when deal with the left side, the guitar pick would better go as the direction of the mark.
  3. Sony Xperia Z3 Dual Teardown: 3 단계, 이미지 1/2 Sony Xperia Z3 Dual Teardown: 3 단계, 이미지 2/2
    • Release battery connector.
    • Free the fastening sticker.
  4. Sony Xperia Z3 Dual Teardown: 4 단계, 이미지 1/2 Sony Xperia Z3 Dual Teardown: 4 단계, 이미지 2/2
    • Pry up and remove the battery.
    • 3100mAh battery.
  5. Sony Xperia Z3 Dual Teardown: 5 단계, 이미지 1/1
    • Twist off screws.
  6. Sony Xperia Z3 Dual Teardown: 6 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown: 6 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown: 6 단계, 이미지 3/3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Teardown: 7 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown: 7 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown: 7 단계, 이미지 3/3
    • Release all the connectors.
    • Remove sim tray before removing motherboard.
    • Remove the motherboard carefully.
  8. Sony Xperia Z3 Dual Teardown: 8 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown: 8 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown: 8 단계, 이미지 3/3
    • That's Sony Xperia Z3 Dual motherboard.
  9. Sony Xperia Z3 Dual Teardown: 9 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown: 9 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown: 9 단계, 이미지 3/3
    • Remove front camera and rear camera.
  10. Sony Xperia Z3 Dual Teardown: 10 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown: 10 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown: 10 단계, 이미지 3/3
    • Remove that blocker beside the earpiece speaker at first.
    • And then you can pry up the earpiece speaker and remove it.
  11. Sony Xperia Z3 Dual Teardown: 11 단계, 이미지 1/1
    • Remove transparent securing cover beside of earphone jack.
  12. Sony Xperia Z3 Dual Teardown: 12 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown: 12 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown: 12 단계, 이미지 3/3
    • Pry to turn the flex cover on the earphone jack. But it's a part of the earphone jack assembly.
    • Cut the adhesive sticker between the earphone jack and midframe and remove the assembly.
  13. Sony Xperia Z3 Dual Teardown: 13 단계, 이미지 1/1
    • That's antenna signal flex.
  14. Sony Xperia Z3 Dual Teardown: 14 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown: 14 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown: 14 단계, 이미지 3/3
    • Twist off screws.
    • Release connectors.
    • Remove vibrator securing bracket.
  15. Sony Xperia Z3 Dual Teardown: 15 단계, 이미지 1/3 Sony Xperia Z3 Dual Teardown: 15 단계, 이미지 2/3 Sony Xperia Z3 Dual Teardown: 15 단계, 이미지 3/3
    • Remove loudspeaker assembly securing bracket. And there is no any adhesive.
    • Pry up and remove the loudspeaker assembly. No adhesive, too.
  16. Sony Xperia Z3 Dual Teardown: 16 단계, 이미지 1/1
    • Done.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 9개
Can you put it back together?
zarixevolve - 답글
I dropped mine so I just want to take the battery out is it possibly to take it and then put it back in
zarixevolve - 답글
hi.after changing my xperia z3 dual lcd 3 times.i hade a fluctuating and very week 3g and 4g signal.plz tell me where is the antenna located.i know that there is a flex and a board and antenna cover.what should i change.thanx
zein hamza - 답글
That's not a complete teardown. I would like to see the onboard chips and info's.
emmacorsa17 - 답글
Where can i buy the Sony Xperia Z3 plus Dual motherboard ?
I really need it.
Kwar Kwar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 24
전체 시간: 39,205
