주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Sony Xperia Z4 수리는 저희 서비스 설명서를 사용하십시오.
  1. Remove back cover. Remove back cover.
    • Remove back cover.
  2. Remove battery. Remove battery. Remove battery.
    • Remove battery.
  3. Release all the connectors on board and remove the screws there. Release all the connectors on board and remove the screws there.
    • Release all the connectors on board and remove the screws there.
  4. Remove that small securing bracket. Remove that small securing bracket.
    • Remove that small securing bracket.
  5. Remove rear camera and front camera. Remove rear camera and front camera. Remove rear camera and front camera.
    • Remove rear camera and front camera.
  6. Remove motherboard. Remove motherboard.
    • Remove motherboard.
  7. Remove sensor flex. Remove sensor flex. Remove sensor flex.
    • Remove sensor flex.
  8. 필수 도구 키트
    최고의 소형 키트에서 가장 유용한 도구.
    지금 쇼핑하기
    필수 도구 키트
    지금 쇼핑하기
  9. Remove two pieces of cover brackets on the audio jack. Remove two pieces of cover brackets on the audio jack. Remove two pieces of cover brackets on the audio jack.
    • Remove two pieces of cover brackets on the audio jack.
  10. Cut the adhesive on the top of the audio jack and remove the audio jack assembly. Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
    • Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
  11. Remove signal cable.
    • Remove signal cable.
  12. Release connectors connecting on the antenna logic board and finally remove it. Release connectors connecting on the antenna logic board and finally remove it. Release connectors connecting on the antenna logic board and finally remove it.
    • Release connectors connecting on the antenna logic board and finally remove it.
  13. Release LCD connector there and loosen the bottom of the whole flex. Release LCD connector there and loosen the bottom of the whole flex.
    • Release LCD connector there and loosen the bottom of the whole flex.
  14. Remove main flex. Remove main flex. Remove main flex.
    • Remove main flex.
  15. Remove loudspeaker securing bracket. Remove loudspeaker securing bracket.
    • Remove loudspeaker securing bracket.
  16. Remove loudspeaker hidden under the flex. Remove loudspeaker hidden under the flex.
    • Remove loudspeaker hidden under the flex.
  17. Push the USB port out of the slot. Push the USB port out of the slot.
    • Push the USB port out of the slot.
  18. Remove USB charging flex assembly. Remove USB charging flex assembly.
    • Remove USB charging flex assembly.
  19. Remove earpiece speaker. Remove earpiece speaker.
    • Remove earpiece speaker.
  20. Remove the metal bracket covering on the screen flex. Remove the metal bracket covering on the screen flex.
    • Remove the metal bracket covering on the screen flex.
  21. Remove LCD screen carefully. Remove LCD screen carefully. Remove LCD screen carefully.
    • Remove LCD screen carefully.
  22. Done.
    • Done.
Sophia
회원 가입일: 2014년 03월 25일
43,168 평판
안내서 62개 작성하였습니다
Is it possible to replace the nylon corners? I've heard it was possible in the previous xperia z devices like z2 and z3. Unfortunately I couldn't find the replacement corners for z3+ or z4 anywhere. Anyone has any idea about it?
Sanket - 답글
Late answer, but it seems like there’s replacement parts for the corners now. I don’t know how to replace them, though.
Farie Indriawan -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 47
30일 전: 188
전체 시간: 31,421
