주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Sony Xperia Z5 수리는 저희 서비스 설명서를 사용하십시오.
  1. Sony Xperia Z5 Teardown, Sony Xperia Z5 Teardown: 1 단계, 이미지 1/2 Sony Xperia Z5 Teardown, Sony Xperia Z5 Teardown: 1 단계, 이미지 2/2
    • Remove SIM card tray.
  2. Sony Xperia Z5 Teardown: 2 단계, 이미지 1/2 Sony Xperia Z5 Teardown: 2 단계, 이미지 2/2
    • Heat the back cover to soften the adhesive.
    • Place the suction cup and insert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 Teardown: 3 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 3 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 3 단계, 이미지 3/3
    • Insert the guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover. The back cover is glass, so only use a sucker if you're experienced. otherwise use a small blade to lift off the back while the glue is soft.
  4. Sony Xperia Z5 Teardown: 4 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 4 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 4 단계, 이미지 3/3
    • Release battery connector and pull off the adhesive tape underneath.
    • Pry up battery.
  5. Sony Xperia Z5 Teardown: 5 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 5 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 5 단계, 이미지 3/3
    • Release rear camera connector, front camera connector, audio jack flex connector and main flex connector on the motherboard and remove the screws there.
    • Take away the plastic bracket.
  6. Sony Xperia Z5 Teardown: 6 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 6 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 6 단계, 이미지 3/3
    • Remove metal cover securing loudspeaker and twist off screws.
    • Pry up and loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 Teardown: 7 단계, 이미지 1/2 Sony Xperia Z5 Teardown: 7 단계, 이미지 2/2
    • Remove main flex. ( Attention: the fingerprint sensor connector is here, be careful to loosen it)
  8. Sony Xperia Z5 Teardown: 8 단계, 이미지 1/2 Sony Xperia Z5 Teardown: 8 단계, 이미지 2/2
    • This is main flex assembly. (It comes with loudspeaker and vibration motor )
  9. Sony Xperia Z5 Teardown: 9 단계, 이미지 1/2 Sony Xperia Z5 Teardown: 9 단계, 이미지 2/2
    • Remove rear camera.
  10. Sony Xperia Z5 Teardown: 10 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 10 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 10 단계, 이미지 3/3
    • Remove that securing bracket, then remove front camera.
  11. Sony Xperia Z5 Teardown: 11 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 11 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 11 단계, 이미지 3/3
    • Release connectors on the motherboard.
    • Remove motherboard.
  12. Sony Xperia Z5 Teardown: 12 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 12 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 12 단계, 이미지 3/3
    • Remover cover bracket on the audio jack.
    • Cut adhesive at the top of the audio jack and noise canceling mic, then remove it.
  13. Sony Xperia Z5 Teardown: 13 단계, 이미지 1/1
    • This is audio jack flex coming with noise canceling mic.
  14. Sony Xperia Z5 Teardown: 14 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 14 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 14 단계, 이미지 3/3
    • Cut the adhesive underneath the earpiece and remove the earpiece.
  15. Sony Xperia Z5 Teardown: 15 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 15 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 15 단계, 이미지 3/3
    • Push the charging port flex out of the slot and remove it.
  16. Sony Xperia Z5 Teardown: 16 단계, 이미지 1/3 Sony Xperia Z5 Teardown: 16 단계, 이미지 2/3 Sony Xperia Z5 Teardown: 16 단계, 이미지 3/3
    • Remove the microphone.
  17. Sony Xperia Z5 Teardown: 17 단계, 이미지 1/1
    • Done.
Lenka
회원 가입일: 11/06/15
2,384 평판
안내서 6개 작성하였습니다
댓글 23개
No Service after a tear down. What is the problem?
Yuhao Min - 답글
it is hard to define which part causes such problem. Make sure the signal antenna connects with logic board perfectly.
Witrigs -
Would the water proof go out because of the removal/teardown ?
Tam Alden - 답글
Most likely. The back is glued on so unless you can make that seal perfect again, the phone wont be water proof.
Discalimer: I don't own a z5 and have never taken one apart but I have dissasembled my z3 to replace the screen and they look very similar.
Kip K -
Hi Lenka,
short question was that a normal xperia z5 or the dual SIM Version because it looks like the SIM reader is long enough to Support two SIM cards. It would be nice if you could check if there are two SIM ports here.
Tobias K - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 46
30일 전: 158
전체 시간: 140,331
