주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Speakal iPanda 수리는 저희 서비스 설명서를 사용하십시오.
  1. Speakal iPanda Teardown, Speakal iPanda Teardown: 1 단계, 이미지 1/1
    • The happy Panda
  2. Speakal iPanda Teardown: 2 단계, 이미지 1/3 Speakal iPanda Teardown: 2 단계, 이미지 2/3 Speakal iPanda Teardown: 2 단계, 이미지 3/3
    • Flip it to find the screws.
    • Unscrew the four Phillips #0 screws.
  3. Speakal iPanda Teardown: 3 단계, 이미지 1/2 Speakal iPanda Teardown: 3 단계, 이미지 2/2
    • Be careful with the cables of the subwoofer.
  4. Speakal iPanda Teardown: 4 단계, 이미지 1/2 Speakal iPanda Teardown: 4 단계, 이미지 2/2
    • He look like this on his insides.
    • there is a little lock on the sides.
    • Don't forget these screws too.
  5. Speakal iPanda Teardown: 5 단계, 이미지 1/2 Speakal iPanda Teardown: 5 단계, 이미지 2/2
    • Opening the sandwich.
    • Don't forget the cables!
  6. Speakal iPanda Teardown: 6 단계, 이미지 1/3 Speakal iPanda Teardown: 6 단계, 이미지 2/3 Speakal iPanda Teardown: 6 단계, 이미지 3/3
    • It doens't look like a panda anymore.
  7. Speakal iPanda Teardown: 7 단계, 이미지 1/1
    • Removing the board, it's all done.
  8. Speakal iPanda Teardown: 8 단계, 이미지 1/2 Speakal iPanda Teardown: 8 단계, 이미지 2/2
    • Poor panda...
paulostool
회원 가입일: 06/06/11
121 평판
안내서 1개 작성함
댓글 3개
Hi!
I have just wondered about tweeter type.
I have a pig, bud one of it's tweeters is dead.
Do you have any idea how to get a replacement tweeter?
THX!!
sonofhoegaarden - 답글
Hello All,
Please can you assist me with sourcing a amplifier board for the Shox Panda as above in the panda tear down. My panda is supplying 12 Vots DC to the woofer. Thanks very much.
Peter Boucher - 답글
Hi Peter, you may consider swapping the actual CD7377CZ Audio Amp for a ST Microelectronics TDA7375V, and probably the RM2576-5.0 voltage regulator with a Texas Instruments LM2576-5.0, both of which are drop-in replacement (as parts are chinese knock-offs).
Cheers !
grogcw - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 5,047
