해당 분해도에 사용된 도구
소개
This 4GB 3.6" Touch Video MP3 Player can be found at BigLots for only 45 dollars. I'll show you how to disassemble it.:Update By htimreimer
해당 분해도는 수리 안내서가 아닙니다. Sylvania SMPK4230 수리는 저희 서비스 설명서를 사용하십시오.
  1. The Layout The Layout The Layout
    • The Layout
  2. I used a pair of fingernale clippers to gently pry open the case at the MicroSD card slot. A slight twisting action will pop it off. Just be sure not to go to far in and damage the unit. I used a pair of fingernale clippers to gently pry open the case at the MicroSD card slot. A slight twisting action will pop it off. Just be sure not to go to far in and damage the unit. I used a pair of fingernale clippers to gently pry open the case at the MicroSD card slot. A slight twisting action will pop it off. Just be sure not to go to far in and damage the unit.
    • I used a pair of fingernale clippers to gently pry open the case at the MicroSD card slot. A slight twisting action will pop it off. Just be sure not to go to far in and damage the unit.
  3. Be careful when opening the unit. The speaker is attached to the back cover and the wires are fragile. The speaker is held in by some double sided sticky tape. Just use your fingernale and pull up on the edge. DO NOT PULL ON THE WIRES... Be careful when opening the unit. The speaker is attached to the back cover and the wires are fragile. The speaker is held in by some double sided sticky tape. Just use your fingernale and pull up on the edge. DO NOT PULL ON THE WIRES...
    • Be careful when opening the unit. The speaker is attached to the back cover and the wires are fragile. The speaker is held in by some double sided sticky tape. Just use your fingernale and pull up on the edge. DO NOT PULL ON THE WIRES...
  4. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Once you have the back cover off you can see that the battery is help in by double sided sticky tape. Gently pull up on the battery and move it to the side. Once you have the back cover off you can see that the battery is help in by double sided sticky tape. Gently pull up on the battery and move it to the side. Once you have the back cover off you can see that the battery is help in by double sided sticky tape. Gently pull up on the battery and move it to the side.
    • Once you have the back cover off you can see that the battery is help in by double sided sticky tape. Gently pull up on the battery and move it to the side.
  6. There are four screws one in each corner. Remove them and gently pull out the LCD Screen keep in mind for the buttons. There are four screws one in each corner. Remove them and gently pull out the LCD Screen keep in mind for the buttons. There are four screws one in each corner. Remove them and gently pull out the LCD Screen keep in mind for the buttons.
    • There are four screws one in each corner. Remove them and gently pull out the LCD Screen keep in mind for the buttons.
  7. RK2705 200MHz CPU By RockChip 128MB SDRAM 166MHZ 54-TSOPII By Winbond Hynix H27UBG8T2MYR-BC  32G bit Nand Flash 4Gx8 Delivery
    • RK2705 200MHz CPU By RockChip
    • 128MB SDRAM 166MHZ 54-TSOPII By Winbond
    • Hynix H27UBG8T2MYR-BC 32G bit Nand Flash 4Gx8 Delivery
  8. A closer look at the LCD and Board. A closer look at the LCD and Board.
    • A closer look at the LCD and Board.
Steve Crawford
회원 가입일: 2010년 09월 17일
31 평판
안내서 1개 작성함
hi ... my screen is damaged, it crash, so, i can't handle, is fact fixit or buy another one??? my e-mail is betito_1126@yahoo.com
ROBERTO LLAMAS - 답글
My screen is damaged. How can I purchase another one? my Email is Harelijah@juno.com
Bernard Harland - 답글
Hi, I wanted to know what the measurements (width,length and thickness), volts and mah of the battery. Even a link to a replacement battery would work. My e-mail is micro065@msn.com
Jim - 답글
The battery is 3.7v 800mAh. Its dimensions are 60mm x 37.5mm x 3.6mm
There appears to be enough room in the case to replace it with something similar to: www.sparkfun.com/products/339
But I have not tried it, so I can't be 100% sure (the thickness may be a problem)
Elexorien - 답글
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 11,583
