주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. T-Mobile Huawei Prism U8651T 수리는 저희 서비스 설명서를 사용하십시오.
  1. T-Mobile Huawei Prism U8651T Teardown, Remove Back Cover Panel: 1 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Remove Back Cover Panel: 1 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Remove Back Cover Panel: 1 단계, 이미지 3/3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T Teardown, Remove Battery: 2 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Remove Battery: 2 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Remove Battery: 2 단계, 이미지 3/3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T Teardown, Torx Screws: 3 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Torx Screws: 3 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Torx Screws: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    T4 Torx Screwdriver
    $5.99
    구매
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T Teardown, Remove Plastic Mid Frame: 4 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Remove Plastic Mid Frame: 4 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Remove Plastic Mid Frame: 4 단계, 이미지 3/3
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T Teardown, Remove Power and Volume Buttons: 5 단계, 이미지 1/2 T-Mobile Huawei Prism U8651T Teardown, Remove Power and Volume Buttons: 5 단계, 이미지 2/2
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T Teardown, Remove Power Button Sensor Strip: 6 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Remove Power Button Sensor Strip: 6 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Remove Power Button Sensor Strip: 6 단계, 이미지 3/3
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T Teardown, Remove Volume Button Sensor Strip: 7 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Remove Volume Button Sensor Strip: 7 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Remove Volume Button Sensor Strip: 7 단계, 이미지 3/3
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T Teardown, Remove Outer Screen Connector: 8 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Remove Outer Screen Connector: 8 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Remove Outer Screen Connector: 8 단계, 이미지 3/3
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T Teardown, Remove Inner Screen Connector: 9 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Remove Inner Screen Connector: 9 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Remove Inner Screen Connector: 9 단계, 이미지 3/3
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T Teardown, Remove Motherboard: 10 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Remove Motherboard: 10 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Remove Motherboard: 10 단계, 이미지 3/3
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T Teardown, Remove Screen: 11 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Teardown, Remove Screen: 11 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Teardown, Remove Screen: 11 단계, 이미지 3/3
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
  12. T-Mobile Huawei Prism U8651T Teardown: 12 단계, 이미지 1/1
    • Teardown complete
Dillon
회원 가입일: 10/23/14
578 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-7, Lauer Fall 2014 Michigan Tech, Team 1-7, Lauer Fall 2014 회원
MTU-LAUER-F14S1G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 9
전체 시간: 2,342
