주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
  1. TELUS Wi-Fi Hub (Arcadyan) Teardown, TELUS Wi-Fi Hub (Arcadyan) Teardown: 1 단계, 이미지 1/3 TELUS Wi-Fi Hub (Arcadyan) Teardown, TELUS Wi-Fi Hub (Arcadyan) Teardown: 1 단계, 이미지 2/3 TELUS Wi-Fi Hub (Arcadyan) Teardown, TELUS Wi-Fi Hub (Arcadyan) Teardown: 1 단계, 이미지 3/3
    • External photos.
  2. TELUS Wi-Fi Hub (Arcadyan) Teardown, External Photo 2: 2 단계, 이미지 1/1
    • External photo 2
  3. TELUS Wi-Fi Hub (Arcadyan) Teardown, Internal Structure: 3 단계, 이미지 1/2 TELUS Wi-Fi Hub (Arcadyan) Teardown, Internal Structure: 3 단계, 이미지 2/2
    • A large heatsink on the back of the unit serves to keep the unit cool without installation of a fan.
Christine Tan
회원 가입일: 01/08/20
117 평판
안내서 1개 작성함
댓글 9개
Oh nice Absolutely amazing, thank you for sharing your knowledge with me.
Laluna Lawlence - 답글
Thank you for tearing it down. Any hint on the speed of the LAN/WAN port from the hardware?
Ricky Chau - 답글
The router seems to be build on Broadcom’s 6858 SoC which is quite powerful beast and MoCA part is on BCM6802. But I can’t find much details about them.
Ajax - 답글
How was it identified as an Arcadyan NH20A? It says designed in Canada on the bottom. Who makes the Arcadyan NH20A. It's not an easy find.
Arcadyan Headquarters: No.8, Sec.2, Guangfu Rd., Hsinchu City 30071, Taiwan. Not a Canadian company. So it was designed for Canadian use only, care of Telus?
Broadband access, Multimedia and Wireless infrastructure into its expertise.
https://www.arcadyan.com/en-us
Where is it stated that this device is made by Arcadyan? I can't find this device within their company website. Someone must have discovered it labeled on the device, somewhere?
ImaGUIguy - 답글
So this ONT/Modem/Router/Wi-Fi 6 device gets fed a fiber optic cable, straight from outside, or does it go through another device first? Like the old Actiontec T3200M it has a fiber in connector (though isn't used in conjunction with the Nokia G-240G-A ONT) with 1G service plan. My T3200 is just fed a CAT6 ethernet cable from the Nokia. The T3200 is only capable of 1G LAN ethernet, I assume this NH20A device has 2.5G LAN ethernet connectors, using CAT6e or CAT7 cables?
ImaGUIguy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 63
30일 전: 256
전체 시간: 19,335
