소개
This TL-WR802N router is designed for mobile use, with speeds up to 300 Mbps. It uses a micro USB port for power only, and only has 1 ethernet port.
필요한 것
Inside the device contains:
Speeds up to 300 Mbps; 2x2 MIMO antenna setup; 5 modes which can turn it into a WiFi extender, or a Wi-Fi client to connect wired only devices to Wi-Fi.
On the outside:
Green LED indicator
10/100 Ethernet port; can be used as a WAN or LAN
Micro USB for power
Recessed Reset Button
On the front of the board:
Qualcomm Atheros QCA9533-AL3A SoC
Running at a speed of 560 MHz
Uses the MIPS 24Kc architecture
Contains an integrated Ethernet switch and wireless radio built in.
2 soldered antennas that allows a MIMO configuration of 2x2:2.
Most of the information that I can obtain are from Wikidevi at: https://wikidevi.com/wiki/Qualcomm_Ather...
And that's It!
The router in this teardown is v1.0. There is another version of the same router, called V2.0, which is virtually identical, however it will only accept firmware that was sold in that country.
For a very small device it can do alot! But it can do more if the OpenWrt/LEDE firmware was ported over.
댓글 8개
Is it possible to remove the 2 antennas and ad external antennas instead… and how Should it be done…
Best regards
Hi
Is it possible to remove the 2 antennas and replace them with external antennas instead… and how should this be done…
Best regards
i’m sure you can just how you do it i’m not sure
Luke -
This TP Link Router is awesome. I like it. i think we can add external antennas in it.
flash openwrt
tianxiaobo - 답글
