주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Toaster 수리는 저희 서비스 설명서를 사용하십시오.
  1. Teardown: Breville Toaster, Breville Toaster Teardown: 1 단계, 이미지 1/1
    • Breville Toaster.
    • The toaster before the teardown process.
  2. Teardown: Breville Toaster: 2 단계, 이미지 1/3 Teardown: Breville Toaster: 2 단계, 이미지 2/3 Teardown: Breville Toaster: 2 단계, 이미지 3/3
    • Turn the toaster upside-down.
    • Use the drill to unscrew the six slotted Spanner head screws
    • Use the drill with corresponding screwdriver bit to remove the Truss Phillip screws
    • The Slotted Spanner head screws hold the four rubber feet at the bottom of the casing.
  3. Teardown: Breville Toaster: 3 단계, 이미지 1/1
    • Unattach the four rubber feet.
  4. Teardown: Breville Toaster: 4 단계, 이미지 1/3 Teardown: Breville Toaster: 4 단계, 이미지 2/3 Teardown: Breville Toaster: 4 단계, 이미지 3/3
    • Detach the timer knob using a flat head screw driver
    • Remove the internal components from the red casing
  5. Teardown: Breville Toaster: 5 단계, 이미지 1/3 Teardown: Breville Toaster: 5 단계, 이미지 2/3 Teardown: Breville Toaster: 5 단계, 이미지 3/3
    • Note: Red casing is still attached to the interior body of the toaster.
    • Detach electric circuit housing from red casing
  6. Teardown: Breville Toaster: 6 단계, 이미지 1/2 Teardown: Breville Toaster: 6 단계, 이미지 2/2
    • Firstly, unscrew the four Pan Phillip head screws
    • Then snap off the three welded plastic studs to detach the timer knob housing from the red casing
  7. Teardown: Breville Toaster: 7 단계, 이미지 1/3 Teardown: Breville Toaster: 7 단계, 이미지 2/3 Teardown: Breville Toaster: 7 단계, 이미지 3/3
    • Unfasten the two Pan Phillip head screws to detach the buttons' housing
  8. Teardown: Breville Toaster: 8 단계, 이미지 1/3 Teardown: Breville Toaster: 8 단계, 이미지 2/3 Teardown: Breville Toaster: 8 단계, 이미지 3/3
    • Note: There are two housings attach to both side of the interior body of the toaster.
    • Remove the two Pan Phillip head screws to detach the circuit board from the heat controller housing.
    • Then, remove the slider as well.
  9. Teardown: Breville Toaster: 9 단계, 이미지 1/3 Teardown: Breville Toaster: 9 단계, 이미지 2/3 Teardown: Breville Toaster: 9 단계, 이미지 3/3
    • Remove the circuit board housing for the heat controller from the interior body of the toaster by unscrewing two Pan Phillip head screws
    • Remove the cable fasteners using a flat head screw driver
  10. Teardown: Breville Toaster: 10 단계, 이미지 1/3 Teardown: Breville Toaster: 10 단계, 이미지 2/3 Teardown: Breville Toaster: 10 단계, 이미지 3/3
    • Separate the interior body of the toaster from the bottom cover.
    • Remove the screw caps
    • Unscrew the two Pan Phillip head screws to detach the aluminium vent
  11. Teardown: Breville Toaster: 11 단계, 이미지 1/3 Teardown: Breville Toaster: 11 단계, 이미지 2/3 Teardown: Breville Toaster: 11 단계, 이미지 3/3
    • Use pliers to break apart the welded wires from the interior body.
    • Snip off the rest of the wires still attached to the interior body using a wire cutter
    • Remove the circuit board from its housing
  12. Teardown: Breville Toaster: 12 단계, 이미지 1/2 Teardown: Breville Toaster: 12 단계, 이미지 2/2
    • Separate the electric components from the interior body
  13. Teardown: Breville Toaster, Components of the Toaster Teardown: 13 단계, 이미지 1/1
    • Insert wisdom here.
Aisyah Azmi
회원 가입일: 09/30/18
217 평판
안내서 1개 작성함
댓글 11개
Don’t buy this toaster…They fail and Breville won’t warranty it after 1 year….
Never again Breville..
James Payne - 답글
Thank you for this tear down guide. Though it’s built pretty well and feels like a tank, It doesn’t seem very repairable. Mine stopped working a couple months ago and I’m contemplating throwing it out. Comments?
David Vileta - 답글
any chance you still have the electronics for the toaster. Mine stopped working. It’s not the heating element. I THINK the issue is one of the components on the circuit board failed. I’ll buy the harness with the PCB from you, if it’s still around. Thanks.
Riccardo - 답글
Thanks very much for posting all of this, gave me the confidence to 'go in'.
Foe anyone thinking of doing what I just did; the guts of a plastic cased model can be put into a metal cased model but there are a few differences but everything you need is there.
Sean Johnson - 답글
Purchased a Breville die cast 2 slice toaster ($160). After one year it stopped toasting evenly and then on the out side of one slice. I am capable of fixing this but Breville will not sell parts, they want you to buy a new one. My first and last Breville product.
Lou Viscomi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 64
30일 전: 241
전체 시간: 19,486
