주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Technics EAH-AZ70 (Japan) Bluetooth Headphones 수리는 저희 서비스 설명서를 사용하십시오.
  1. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown, Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 1 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown, Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 1 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown, Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 1 단계, 이미지 3/3
    • Features:
    • Highest Level of Dual Hybrid Noise Cancelling. Multiple MEMS microphones
    • Graphene coated PEEK diaphragm speaker for smooth, clean, and elegant sound
    • Stable Connection in crowed areas
    • Excellent Quality Call Sound
    • Approximately 6.5 hours of playback, and up to 20 Hours of use with charger
    • Bluetooth® 5.0
    • Capacitive touch sensor control
  2. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 2 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 2 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 2 단계, 이미지 3/3
    • What is in the box
    • Headphones / Charging Case
    • USB 'C' Cable
    • Headphone rubber tips for different sizes of ears
    • User's Manual
  3. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 3 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 3 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 3 단계, 이미지 3/3
    • Charging case with headphones
    • Close up view of headphones
  4. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 4 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 4 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 4 단계, 이미지 3/3
    • Side views of Headphone
    • Charger Interface
    • USB Interface
    • Speaker Sound Port
    • MEMS Microphones
    • Speaker Vent
    • Vent Port
    • Speaker Spatial Vent Port
  5. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 5 단계, 이미지 1/2 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 5 단계, 이미지 2/2
    • View of Headphone with rubber ear piece removed
    • Vent Port
  6. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 6 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 6 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 6 단계, 이미지 3/3
    • Since the Technics Headphone enclosure is glued together, the only way in was to cut into the headphone.
    • This is a destructive teardown
    • A Razsor knife was use to cut into the Technics headphone along the seam in the headphone. Then a Jimmy Tool was used to open up the headphone. Tweezers and a Pick Tool were used to removed the electronics from the enclosure
    • Once opened, we get our first look at the inside of the headphone
    • Double sided foam tape was used to hold the main the PCB to the Battery and to the Touch Sensor / Antenna PCB. This foam tape had to be cut free. Then Denatured Alcohol was used to remove the foam tape glue from the PCBs and Battery
    • Double Sided Foam Tape
  7. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 7 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 7 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 7 단계, 이미지 3/3
    • Opening up the headphone, we can see the main PCB, Battery, Speaker, etc
    • Battery
    • Main PCB
    • Speaker
    • Speaker Sound Chamber
    • Touch Sensor and Antenna
  8. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 8 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 8 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 8 단계, 이미지 3/3
    • At first, I wasn't sure about the solder balls. Then I realized they were used to anchor the USB and Power Interface pins on the outside of the Headphone to the internal circuit board.
    • I had to used a solder iron to remove the solder balls, so that the internal interface circuit board could be removed. I had to also remove solder from the speaker wires to free up the internal circuit board.
    • Internal Circuit Board that interface Power and USB to the Headphones
  9. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 9 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 9 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 9 단계, 이미지 3/3
    • The internal circuit board was also attached a MEMS Microphone that appeared to be monitoring the Speaker Chamber of the Headphone, since it was faced in
    • I had to remove the outside panel with 'R' on it with a Razor Knife to free the MEMS Microphone. Once the MEMS Microphone was freed, the interface board circuit could be pulled out
    • USB and Power (Charger) Interface
    • Sound Ports
    • MEMS Microphone from plastic collar in the Headphone
    • MEMS Microphone separated from the Interface Circuit Board when removed from the side of the Speaker Chamber
  10. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 10 단계, 이미지 1/2 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 10 단계, 이미지 2/2
    • There was not much to see on the internal interface board top side or bottom side. The was one IC component that could not be crossed. If you happen to know the component, please leave a comment below
    • Unknown Component
  11. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 11 단계, 이미지 1/2 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 11 단계, 이미지 2/2
    • Full Sensor Flex/Charging PCB IC Identification:
    • You may need to enlarge the picture to view the text.
  12. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 12 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 12 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 12 단계, 이미지 3/3
    • Next the Speaker sound chamber cover was removed with the use of a Pick Tool and Tweezers. A Razor Knife was used to cut the glue holding the speak in place
    • The speaker had no identifiable markings
    • With Speaker removed, we can see the sound chamber and sound ports
  13. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 13 단계, 이미지 1/2 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 13 단계, 이미지 2/2
  14. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 14 단계, 이미지 1/2 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 14 단계, 이미지 2/2
    • Closeup view of the Antenna/Touch Sensor side of the Main PCB
    • DSP Group - C2A1A Hybrid Active Noise Cancellation (ANC) Codec and Audio Digital Signal Processor (DSP)
    • 651DF1M9 - Could not cross part number, but during a web search found out that it may be an integrated battery management IC
    • W25Q32JWUUIMTR- SPI FLASH 32Mb
    • MEMS Microphone Port
  15. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 15 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 15 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 15 단계, 이미지 3/3
    • Closeup view of some of the components on the Antenna/Touch Sensor side of the Main PCB
    • Winbond-W25Q32JWUUIMTR SPI FLASH 32Mb
  16. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 16 단계, 이미지 1/2 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 16 단계, 이미지 2/2
    • Battery side close up view of the Main PCB
    • AIROHA AB1552 - ARM Cortex M4/Bluetooth 5.0 Dual Mode
    • 913 MPS1 MEMS Microphone. The Headphone uses three MEMS microphones with this part number
    • Could not cross the part number. If you know the part, please leave a comment below. The 2D bar code on the part reads as STM9135G15JAS011
    • Crystal Oscillator
    • Unknown component. Labelled B2A. Please leave a comment if you happen to know this component
    • Unknown component. Labelled SV4CP 240. Please leave a comment if you happen to know this component. Separated from PCB during teardown
  17. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 17 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 17 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 17 단계, 이미지 3/3
    • Closeup view of some of the components on the Battery side of the Main PCB
  18. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 18 단계, 이미지 1/2 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 18 단계, 이미지 2/2
    • Closeup view of top and bottom side of the Touch Sensor Flex PCB and Antenna
  19. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 19 단계, 이미지 1/2 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 19 단계, 이미지 2/2
    • Full Main PCB IC Identification:
  20. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 20 단계, 이미지 1/1
    • Predicted Block Diagram of the Technics EAH-AZ70 (Japan) Bluetooth Headphones:
  21. Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 21 단계, 이미지 1/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 21 단계, 이미지 2/3 Technics EAH-AZ70 (Japan) Bluetooth Headphones Teardown: 21 단계, 이미지 3/3
    • Teardown Exploded View of the Technics Headphone
Robert Shuler
회원 가입일: 03/12/19
3,539 평판
안내서 11개 작성하였습니다
4 Comments
If you can, can you post the teardown of the charging case too?
CChin - 답글
same. can you post the teardown of the charging case?
steam hotrice - 답글
Heat up the bottom of charging case to unstiky the glue. It will way much easy take the aluminium case off. Then unplug the black plastic inside case and you can see the battery and pcb
Jun - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 23
전체 시간: 1,474
