주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Tesco Value JK07 Kettle 수리는 저희 서비스 설명서를 사용하십시오.
  1. Tesco Value JK07 Kettle Teardown, Tesco Value JK07 Kettle Teardown: 1 단계, 이미지 1/2 Tesco Value JK07 Kettle Teardown, Tesco Value JK07 Kettle Teardown: 1 단계, 이미지 2/2
    • Remove the kettle from its base.
    • Remove the limescale filter by sliding it out from the lip.
  2. Tesco Value JK07 Kettle Teardown: 2 단계, 이미지 1/3 Tesco Value JK07 Kettle Teardown: 2 단계, 이미지 2/3 Tesco Value JK07 Kettle Teardown: 2 단계, 이미지 3/3
    • Remove the screw from the bottom side of the lid.
    • Disassemble the lid and remove the plastic piece inside.
  3. Tesco Value JK07 Kettle Teardown: 3 단계, 이미지 1/1
    • Remove the button that opens the lid by sliding it out.
  4. Tesco Value JK07 Kettle Teardown: 4 단계, 이미지 1/2 Tesco Value JK07 Kettle Teardown: 4 단계, 이미지 2/2
    • Remove the screws on the underside of the kettle to release the socket cover.
    • Separate the handle from the kettle.
  5. Tesco Value JK07 Kettle Teardown: 5 단계, 이미지 1/2 Tesco Value JK07 Kettle Teardown: 5 단계, 이미지 2/2
    • Remove the screws to separate the handle and the lid from the hinge.
  6. Tesco Value JK07 Kettle Teardown: 6 단계, 이미지 1/3 Tesco Value JK07 Kettle Teardown: 6 단계, 이미지 2/3 Tesco Value JK07 Kettle Teardown: 6 단계, 이미지 3/3
    • Gently remove the switch cover.
    • Remove the circular piece attached to the switch base by gently pulling it away.
  7. Tesco Value JK07 Kettle Teardown: 7 단계, 이미지 1/2 Tesco Value JK07 Kettle Teardown: 7 단계, 이미지 2/2
    • Remove the screws from the socket at the back of the kettle.
    • These screws also hold the socket together, so once they have been removed, it can be opened.
    • The components within the socket are clipped in. Remove the components by gently pulling.
  8. Tesco Value JK07 Kettle Teardown: 8 단계, 이미지 1/2 Tesco Value JK07 Kettle Teardown: 8 단계, 이미지 2/2
    • Remove the heating element.
    • Remove the gasket.
    • Remove the plate beneath the heating element by bending the metal in the holes as shown in the picture. Remove the plate from the clips.
  9. Tesco Value JK07 Kettle Teardown: 9 단계, 이미지 1/1
    • Remove all the screws from the bottom, then gently separate the two halves.
  10. Tesco Value JK07 Kettle Teardown: 10 단계, 이미지 1/1
    • Push the feet (B) out from the base (C).
  11. Tesco Value JK07 Kettle Teardown: 11 단계, 이미지 1/1
    • The plug and cable (G) are held in by clips and can be pulled away.
    • The fuse (F) can be pulled away from inside the pins on the plug (G).
  12. Tesco Value JK07 Kettle Teardown: 12 단계, 이미지 1/1
    • The kettle is now fully disassembled.
    • There should be 26 separate parts, all shown here in this photo.
emily king
회원 가입일: 03/17/10
21 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 22
전체 시간: 7,352
