주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Texas Instruments TI BA II Plus 수리는 저희 서비스 설명서를 사용하십시오.
  1. Texas Instruments TI BA II Plus Teardown, Texas Instruments TI BA II Plus Teardown: 1 단계, 이미지 1/1
    • The BA II Plus Professional calculator.
  2. Texas Instruments TI BA II Plus Teardown: 2 단계, 이미지 1/1
    • Remove the battery cover by sliding it out.
  3. Texas Instruments TI BA II Plus Teardown: 3 단계, 이미지 1/1
    • Firstly on the back cover, remove the small sticky soft cushioning material covering the recess with the screws in it. 4 of them in total. Unscrew them.
  4. Texas Instruments TI BA II Plus Teardown: 4 단계, 이미지 1/1
    • Use a flathead screwdriver to gently part the bottom and top cover at the hinge on the top.
  5. Texas Instruments TI BA II Plus Teardown: 5 단계, 이미지 1/1
    • Removing the back cover to reveal the foil, unscrew the 4 screws holding the foil and 4 other holding the printed circuit board to the front cover.
  6. Texas Instruments TI BA II Plus Teardown: 6 단계, 이미지 1/1
    • Remove the foil. Ensure all screws are off.
  7. Texas Instruments TI BA II Plus Teardown: 7 단계, 이미지 1/1
    • This must separate the front cover from the board. Remove the board and turn it over to view the front side with a soft black cushion cover over a smooth shinny mesh.
  8. Texas Instruments TI BA II Plus Teardown: 8 단계, 이미지 1/1
    • The keys should fall out of the front cover when you turn it over as well. Thats it!!!
VSP
회원 가입일: 06/23/13
101 평판
안내서 1개 작성함
댓글 4개
Well, my TI BA II plus has a broken LCD screen which according to the customer care is not covered under the warranty. Is it possible to find a replacement LCD to replace the broken one in the calculator.
Thanks
VSP - 답글
My calculated get in water, now its not working is there any way to repair it.
ankur - 답글
Did it stopped working immediately ? Also what did u do then
Akshat S Gupta -
This is a terrific service that you are providing. It makes fixing thing so much easier. Thank you.
ROB LYTLE - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 27
전체 시간: 9,164
