주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Texas Instruments TI-30 XS Multiview 수리는 저희 서비스 설명서를 사용하십시오.
  1. Texas Instruments TI-30 XS Multiview Teardown, Remove the back panel: 1 단계, 이미지 1/3 Texas Instruments TI-30 XS Multiview Teardown, Remove the back panel: 1 단계, 이미지 2/3 Texas Instruments TI-30 XS Multiview Teardown, Remove the back panel: 1 단계, 이미지 3/3
    • Using the Phillips head screwdriver, remove the 6 screws
    • Pry the back panel open with the flathead
  2. Texas Instruments TI-30 XS Multiview Teardown, Remove the battery: 2 단계, 이미지 1/2 Texas Instruments TI-30 XS Multiview Teardown, Remove the battery: 2 단계, 이미지 2/2
    • Remove the two screws holding the battery down
    • Take off the metal cover
    • Remove the battery
  3. Texas Instruments TI-30 XS Multiview Teardown, Remove the LCD: 3 단계, 이미지 1/3 Texas Instruments TI-30 XS Multiview Teardown, Remove the LCD: 3 단계, 이미지 2/3 Texas Instruments TI-30 XS Multiview Teardown, Remove the LCD: 3 단계, 이미지 3/3
    • Use the Phillips head screwdriver to remove the two screws securing the LCD to the plastic chassis
    • With the flathead, wedge out the LCD screen without disconnecting the internal wiring
    • This is the furthest that the calculator can be torn down without destroying the calculator beyond repair
  4. Texas Instruments TI-30 XS Multiview Teardown, Reassmble the calculator: 4 단계, 이미지 1/1
    • Reassemble the calculator, placing the LCD screen, battery, back panel, and screws in the proper position
    • After the calculator is reassembled, the calculator truly works as it did before the teardown
Regita Soetandar
회원 가입일: 03/06/19
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 1,043
