주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
  1. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: 1 단계, 이미지 1/3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: 1 단계, 이미지 2/3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: 1 단계, 이미지 3/3
    • Wisdom
  2. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: 2 단계, 이미지 1/2 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: 2 단계, 이미지 2/2
    • Unplug the battery.
    • Be careful not to fray cable while unplugging.
  3. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: 3 단계, 이미지 1/3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: 3 단계, 이미지 2/3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: 3 단계, 이미지 3/3
    • Remove the back cover by removing the 6 Pentalobe screws (P6)
    • The front cover can be taken off by prying it off from the front of the device
    • Then pry off the back cover it can be a little challenging but take your time
  4. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: 4 단계, 이미지 1/3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: 4 단계, 이미지 2/3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: 4 단계, 이미지 3/3
    • Remove the 6 Philips screws holding the mother board and if you want remove the foil just to see the full board itself
    • To change out the buttons take out the grey rubber sheet that separates them from the board (be careful with the buttons as they will fall out)
ArabianBoi1259
회원 가입일: 04/03/20
103 평판
안내서 1개 작성함
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 13
전체 시간: 221
