주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Toaster 수리는 자사의 서비스 설명서를 사용하세요.
  1. Toaster Made by Design model KT-3215 Teardown, Toaster Made by Design model KT-3215 Teardown: 1 단계, 이미지 1개 중 1개
    • This is what a Toaster Made by Design model KT-3215 should look like before the teardown has started.
  2. Toaster Made by Design model KT-3215 Teardown: 2 단계, 이미지 3개 중 1개 Toaster Made by Design model KT-3215 Teardown: 2 단계, 이미지 3개 중 2개 Toaster Made by Design model KT-3215 Teardown: 2 단계, 이미지 3개 중 3개
    • Make sure the toaster is unplugged and not near an electrical outlet.
    • Remove the crumb tray, which is located on the back of the toaster. Slide the crumb tray directly out. No lifting or twisting is required.
  3. Toaster Made by Design model KT-3215 Teardown: 3 단계, 이미지 3개 중 1개 Toaster Made by Design model KT-3215 Teardown: 3 단계, 이미지 3개 중 2개 Toaster Made by Design model KT-3215 Teardown: 3 단계, 이미지 3개 중 3개
    • Use your index finger and middle finger to grip the loading lever, then pull towards your body to remove the lever. A fair amount of force may be required.
  4. Toaster Made by Design model KT-3215 Teardown: 4 단계, 이미지 1개 중 1개
    • Flip the toaster upside down.
    • Use a spudger to remove the two rubber feet.
  5. Toaster Made by Design model KT-3215 Teardown: 5 단계, 이미지 2개 중 1개 Toaster Made by Design model KT-3215 Teardown: 5 단계, 이미지 2개 중 2개
    • Use a TA 2.3 screwdriver to unscrew the five triangular screws on the bottom of the toaster.
  6. Toaster Made by Design model KT-3215 Teardown: 6 단계, 이미지 3개 중 1개 Toaster Made by Design model KT-3215 Teardown: 6 단계, 이미지 3개 중 2개 Toaster Made by Design model KT-3215 Teardown: 6 단계, 이미지 3개 중 3개
    • Lift the toaster casing. This will expose the power splitter cable (white cable).
    • Use a spudger and your thumb, to remove the power splitter cable.
  7. Toaster Made by Design model KT-3215 Teardown: 7 단계, 이미지 2개 중 1개 Toaster Made by Design model KT-3215 Teardown: 7 단계, 이미지 2개 중 2개
    • Place the toaster casing upside down.
    • Use a Phillips #2 x 4in. screwdriver to remove the four 0.25 in. Phillips head screws. These screws are securing the control board for the buttons and timer knob.
  8. Toaster Made by Design model KT-3215 Teardown: 8 단계, 이미지 2개 중 1개 Toaster Made by Design model KT-3215 Teardown: 8 단계, 이미지 2개 중 2개
    • Remove the control board from the toaster casing.
  9. Toaster Made by Design model KT-3215 Teardown: 9 단계, 이미지 3개 중 1개 Toaster Made by Design model KT-3215 Teardown: 9 단계, 이미지 3개 중 2개 Toaster Made by Design model KT-3215 Teardown: 9 단계, 이미지 3개 중 3개
    • Pull the bagel button and cancel button off of the toaster casing. These buttons require little force to remove.
    • Detach the timer knob by pinching the sides of the timer knob and pushing towards the exterior of the toaster casing.
  10. Toaster Made by Design model KT-3215 Teardown: 10 단계, 이미지 3개 중 1개 Toaster Made by Design model KT-3215 Teardown: 10 단계, 이미지 3개 중 2개 Toaster Made by Design model KT-3215 Teardown: 10 단계, 이미지 3개 중 3개
    • Use a pair of mini long-nose pliers to remove the spring components from the timer knob.
  11. Toaster Made by Design model KT-3215 Teardown: 11 단계, 이미지 2개 중 1개 Toaster Made by Design model KT-3215 Teardown: 11 단계, 이미지 2개 중 2개
    • Use a pair of mini long-nose pliers to bend the metal lips located on the back of the toaster. The metal lips should be facing towards you after you have bent them.
    • Remove the waveguide cover (rectangular tan cover) on the back of the toaster.
  12. Toaster Made by Design model KT-3215 Teardown: 12 단계, 이미지 2개 중 1개 Toaster Made by Design model KT-3215 Teardown: 12 단계, 이미지 2개 중 2개
    • Use a Phillips 2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws. This will allow you to remove the metal bracket.
  13. Toaster Made by Design model KT-3215 Teardown: 13 단계, 이미지 2개 중 1개 Toaster Made by Design model KT-3215 Teardown: 13 단계, 이미지 2개 중 2개
    • Use a Phillips 2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws. These screws secure the back of the internal housing of the toaster.
  14. Toaster Made by Design model KT-3215 Teardown: 14 단계, 이미지 2개 중 1개 Toaster Made by Design model KT-3215 Teardown: 14 단계, 이미지 2개 중 2개
    • Use a Phillips 2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws. These screws secure the front of the internal housing of the toaster.
  15. Toaster Made by Design model KT-3215 Teardown: 15 단계, 이미지 3개 중 1개 Toaster Made by Design model KT-3215 Teardown: 15 단계, 이미지 3개 중 2개 Toaster Made by Design model KT-3215 Teardown: 15 단계, 이미지 3개 중 3개
    • Lift the internal housing.
    • Use a pair of mini needle pliers to remove the other end of the power splitter cable.
  16. Toaster Made by Design model KT-3215 Teardown: 16 단계, 이미지 2개 중 1개 Toaster Made by Design model KT-3215 Teardown: 16 단계, 이미지 2개 중 2개
    • Place the internal housing flat on the base of the toaster.
    • Use a pair of mini long-nose pliers to detach the wires that are welded to the internal housing. This may require some force.
  17. Toaster Made by Design model KT-3215 Teardown: 17 단계, 이미지 1개 중 1개
    • Remove the internal housing from the base of the toaster.
  18. Toaster Made by Design model KT-3215 Teardown: 18 단계, 이미지 3개 중 1개 Toaster Made by Design model KT-3215 Teardown: 18 단계, 이미지 3개 중 2개 Toaster Made by Design model KT-3215 Teardown: 18 단계, 이미지 3개 중 3개
    • Use a Phillips #2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws from the plastic fastener.
    • Remove the plastic fastener.
  19. Toaster Made by Design model KT-3215 Teardown: 19 단계, 이미지 2개 중 1개 Toaster Made by Design model KT-3215 Teardown: 19 단계, 이미지 2개 중 2개
    • Remove the main electric controller by gently pushing forward on it then raising it up.
  20. Toaster Made by Design model KT-3215 Teardown: 20 단계, 이미지 1개 중 1개
    • Pull the power cord through the base of the toaster. This will allow separation between the base of the toaster and the main electric controller.
  21. Toaster Made by Design model KT-3215 Teardown, Completed Teardown: 21 단계, 이미지 1개 중 1개
    • The teardown of a Toaster Made by Design Model model KT-3215 is now complete.
작성자
5다른 기여자 명과 함께
Mallory
회원 가입일: 11/15/21
313 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 21
전체 시간: 1,961
