주요 콘텐츠로 건너뛰기
Tungsten E Disassembly
필요한 것
  1. Tungsten E Disassembly, Tungsten E Disassembly: 1 단계, 이미지 1/2 Tungsten E Disassembly, Tungsten E Disassembly: 1 단계, 이미지 2/2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Disassembly: 2 단계, 이미지 1/3 Tungsten E Disassembly: 2 단계, 이미지 2/3 Tungsten E Disassembly: 2 단계, 이미지 3/3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Tungsten E Disassembly: 3 단계, 이미지 1/2 Tungsten E Disassembly: 3 단계, 이미지 2/2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Disassembly: 4 단계, 이미지 1/2 Tungsten E Disassembly: 4 단계, 이미지 2/2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Disassembly: 5 단계, 이미지 1/3 Tungsten E Disassembly: 5 단계, 이미지 2/3 Tungsten E Disassembly: 5 단계, 이미지 3/3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Disassembly: 6 단계, 이미지 1/1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
결론
Kevin Hom
회원 가입일: 01/21/10
103 평판
안내서 2개 작성하였습니다
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 회원
CPSU-MANESS-W10S13G22
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
How does one unplug the battery?
dlcatftwin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 7,786
