주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Uniden EXP 371 수리는 저희 서비스 설명서를 사용하십시오.
  1. Uniden EXP 371 Teardown, Uniden EXP 371 Teardown: 1 단계, 이미지 1/1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Teardown: 2 단계, 이미지 1/2 Uniden EXP 371 Teardown: 2 단계, 이미지 2/2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Teardown: 3 단계, 이미지 1/2 Uniden EXP 371 Teardown: 3 단계, 이미지 2/2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Teardown: 4 단계, 이미지 1/3 Uniden EXP 371 Teardown: 4 단계, 이미지 2/3 Uniden EXP 371 Teardown: 4 단계, 이미지 3/3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
Tim Reimer
회원 가입일: 06/19/10
165 평판
안내서 3개 작성하였습니다
댓글 한 개
this guide is poorly written, please delete or improve it.
Walker Quine - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 9
전체 시간: 4,576
