소개
Having trouble dismantling the Vornado Flippi V6 fan?
This guide shows show you how to disassemble the fan step by step.
필요한 것
Under the base of the fan, remove the four rubber slip guards by peeling them off with your finger tips.
11가이드 댓글
Importantly several of the parts have a specific difference between left and right. The cradle and the fan housing itself have a small and a large “bearing” for setting fan angle. The logo goes down. If they don’t match the cradle you cannot reassemble the fan. I took mine apart because the fan bearings needed oil.
What kind of oil and where exactly do you apply it? I have a couple of these that are getting noisey
Aaron -
I would also like to know what kind of oil and where exactly to apply it? One of mine is squeaking loud enough that I haven't been using it. Taking it apart for a thorough cleaning did not do the trick.
Thanks!
