소개
Having trouble dismantling the Vornado Flippi V6 fan?
This guide shows show you how to disassemble the fan step by step.
필요한 것
Under the base of the fan, remove the four rubber slip guards by peeling them off with your finger tips.
To remove the adjustable speed switch cover, slightly pry off 6 clips located around the switch.
How dificult was it to reassemble the 2 way switch?
How to remove the big black cable, please ???
llullush82 - 답글
댓글 11개
Importantly several of the parts have a specific difference between left and right. The cradle and the fan housing itself have a small and a large “bearing” for setting fan angle. The logo goes down. If they don’t match the cradle you cannot reassemble the fan. I took mine apart because the fan bearings needed oil.
What kind of oil and where exactly do you apply it? I have a couple of these that are getting noisey
Aaron -
I would also like to know what kind of oil and where exactly to apply it? One of mine is squeaking loud enough that I haven't been using it. Taking it apart for a thorough cleaning did not do the trick.
Thanks!
At the basics it's very simple: Drop of oil each on the bearings. Where are the bearings? The 'caps' on the front and back of the motor held on by machine screws, that trap the fan shaft in place. You want the oil to go onto the bronze colored (it's actually bronze!) bushing held on by those grey zinc caps. For reference, the zinc caps are the bits held on by the two screws in the motor that are left after you've taken the motor out of the plastic housing at the end of the instructions.
I went one step further: I took that screw apart (it's a nut and a screw, use a small channel lock and a screwdriver on the other end), removed the bearing caps and the fan shaft, and soaked the bushings in motor oil. I used 10-30 but whatever works. I put them in a dish and used a vacuum container to help get oil into those bushings, took them out, cleaned them off, reassembled and my partner's fan is super quiet now. (No vacuum sealer/container? Just soak overnight.)
Thank you. The guy on YouTube was sticking screw drivers down the front and not really explaining where the clips were. Even though I have the 10 volt version this got me started. Got a piece of yarn wrapped around the base of the blades. Although it was difficult to disassemble, your instructions were good.
Some additional details. Careful of the little ball bearings which you can see in step 7. They could fall out and get lost. It's kind of hard to put back together as well.
Also, At the end when I put it back together, there was some resistance to the fan moving. I set it horizontal, loosened the screws holding the motor to the casing (seen in step 10), turned the fan on, let it spin so it was happy, turned off and unplugged the fan, then tightened those same screws down and it seems happy.
Good tips. As I mentioned above, re-oiling the sintered bronze bushings is a good idea too.
Great post, any sugestions on how to get the rotary switch assebmbly put together?
How to change the big electric cable, please ?
llullush82 - 답글
Yes I want to know how I can take it apart to clean the blades and the inner face and the inner back of fan
angieleehigdon - 답글
