주요 콘텐츠로 건너뛰기
해당 분해도에 사용된 도구
해당 분해도는 수리 안내서가 아닙니다. W8 Android Smart Watch 수리는 저희 서비스 설명서를 사용하십시오.
  1. For the teardown I'll be using the iFixIt Protech Toolkit. It has everything I need and all tools required to do the teardown For the teardown I'll be using the iFixIt Protech Toolkit. It has everything I need and all tools required to do the teardown
    • For the teardown I'll be using the iFixIt Protech Toolkit. It has everything I need and all tools required to do the teardown
  2. Here it is, the W8 Android Smart Watch. Here it is, the W8 Android Smart Watch.
    • Here it is, the W8 Android Smart Watch.
  3. The first step doesn't require any tools. On the back you can take off the back in the left-bottom corner
    • The first step doesn't require any tools.
    • On the back you can take off the back in the left-bottom corner
  4. Something we haven't seen since iPhone got invented. Removable and Replacable battery Under the battery you'll find a slot for a Micro SD card (Not included, added it myself) and a SIM card slot
    • Something we haven't seen since iPhone got invented. Removable and Replacable battery
    • Under the battery you'll find a slot for a Micro SD card (Not included, added it myself) and a SIM card slot
  5. Now  we have to remove the vibration motor, don't be fooled (Like I was), this is NOT a battery! (Thanks for correcting me Pawel) For this I used a simple tweezers
    • Now we have to remove the vibration motor, don't be fooled (Like I was), this is NOT a battery! (Thanks for correcting me Pawel)
    • For this I used a simple tweezers
  6. Next we need to remove the 4 screws in the corners, These can be removed with a 00 head Next we need to remove the 4 screws in the corners, These can be removed with a 00 head Next we need to remove the 4 screws in the corners, These can be removed with a 00 head
    • Next we need to remove the 4 screws in the corners, These can be removed with a 00 head
  7. One more And now.
    • One more
    • And now.
  8. With the 4 screws removed, we can remove the top layer. On the bottom and on the left top there's the speaker
    • With the 4 screws removed, we can remove the top layer.
    • On the bottom and on the left top there's the speaker
    • Is this what they mean with integrated audio?
  9. We can now also remove the band from the watch. If we look closer, inside the band, there's the GSM Antenna (Thanks for the tip Pawel!) If we look closer, inside the band, there's the GSM Antenna (Thanks for the tip Pawel!)
    • We can now also remove the band from the watch.
    • If we look closer, inside the band, there's the GSM Antenna (Thanks for the tip Pawel!)
  10. If there's anything that can't stop us at iFixIt, it's gotta be this. Simply use the Tweezers from your iFixIt Protech Toolkit and your good to go If there's anything that can't stop us at iFixIt, it's gotta be this. Simply use the Tweezers from your iFixIt Protech Toolkit and your good to go
    • If there's anything that can't stop us at iFixIt, it's gotta be this. Simply use the Tweezers from your iFixIt Protech Toolkit and your good to go
  11. Before taking off the board, there's 2 cables you need to unplug first! Note the 2 cables are locked so you'll need to simply push up the lock so you can take out the cables, do this with accuracy and precision, using Tweezers! Now we can take out the board!
    • Before taking off the board, there's 2 cables you need to unplug first!
    • Note the 2 cables are locked so you'll need to simply push up the lock so you can take out the cables, do this with accuracy and precision, using Tweezers!
    • Now we can take out the board!
  12. And now we've come to the end.
    • And now we've come to the end.
    • In such a small device, so much functions. We've learned a lot today.
    • We also learned that a iPhone 5C Camera is no good at taking pictures at close distance!
Lena Fox
회원 가입일: 2017년 12월 12일
736 평판
안내서 1개 작성함
Kid fixers Kid fixers 회원
Community
102 회원들
안내서 64개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 31
전체 시간: 1,373
