주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Whelen Slimlighter Super-LED 수리는 저희 서비스 설명서를 사용하십시오.
  1. Whelen Slimlighter Super-LED Teardown, Whelen Slimlighter Super-LED Teardown: 1 단계, 이미지 1/2 Whelen Slimlighter Super-LED Teardown, Whelen Slimlighter Super-LED Teardown: 1 단계, 이미지 2/2
    • This is Whelen's second generation Slimlighter. Whilst the first generation had multiple 5mm LED's, this generation Slimlighter has 'only' 12 TIR6 style LED's.
    • Enough chatter, let's take it apart :)
  2. Whelen Slimlighter Super-LED Teardown: 2 단계, 이미지 1/3 Whelen Slimlighter Super-LED Teardown: 2 단계, 이미지 2/3 Whelen Slimlighter Super-LED Teardown: 2 단계, 이미지 3/3
    • Optionally one can first take of the suctioncup brackets. They are held in place by two Philips screws.
    • Next you can take off the retaining brackets. They are held back by a little notch that has to be lifted with a spudger. Repeat this step for the other side.
    • Once the notch is lifted pull the bracket away from the light as shown.
  3. Whelen Slimlighter Super-LED Teardown: 3 단계, 이미지 1/3 Whelen Slimlighter Super-LED Teardown: 3 단계, 이미지 2/3 Whelen Slimlighter Super-LED Teardown: 3 단계, 이미지 3/3
    • Once the brackets are released the light can easily be dissasembled. Begin by lifting the diffuser lens up as shown.
    • One can also have clear lenses here, the procedure is the same.
    • Note that the lens has a similar notch on the other side, underneath the Whelen logo. Carefully pull the lens out from underneath, don't force anything or it will break.
  4. Whelen Slimlighter Super-LED Teardown: 4 단계, 이미지 1/3 Whelen Slimlighter Super-LED Teardown: 4 단계, 이미지 2/3 Whelen Slimlighter Super-LED Teardown: 4 단계, 이미지 3/3
    • With the diffuser lenses removed the optics are exposed. They are not secured by anything so carefulle take them out as shown
    • Nifty little optics here, kudo's to Whelen.
    • Try activating the light now, see the differences with and without these optics
  5. Whelen Slimlighter Super-LED Teardown: 5 단계, 이미지 1/3 Whelen Slimlighter Super-LED Teardown: 5 단계, 이미지 2/3 Whelen Slimlighter Super-LED Teardown: 5 단계, 이미지 3/3
    • Now you can CAREFULLY take out the LED assembly. It's attached to a metal heat dissapating bracket. CAREFUL with the wiring. Note that the bracket is retained by the plastic housing. It might need some help before it gives way.
  6. Whelen Slimlighter Super-LED Teardown: 6 단계, 이미지 1/3 Whelen Slimlighter Super-LED Teardown: 6 단계, 이미지 2/3 Whelen Slimlighter Super-LED Teardown: 6 단계, 이미지 3/3
    • The wires are held back /retained by a stickon Whelen logo. The logo can easily be removed, just tear it off carefully.
  7. Whelen Slimlighter Super-LED Teardown: 7 단계, 이미지 1/3 Whelen Slimlighter Super-LED Teardown: 7 단계, 이미지 2/3 Whelen Slimlighter Super-LED Teardown: 7 단계, 이미지 3/3
    • Once the Whelen logo tab is removed the light comes apart completley.
    • Take out the two metal brackets holding the light.
    • Note that one of the brackets holds (part of) the flasher assembly.
  8. Whelen Slimlighter Super-LED Teardown: 8 단계, 이미지 1/3 Whelen Slimlighter Super-LED Teardown: 8 단계, 이미지 2/3 Whelen Slimlighter Super-LED Teardown: 8 단계, 이미지 3/3
    • If desired, take out the six Philips screws to remove the LED circuit board from the bracket.
    • Note that the rear circuit board is held back by the same screws.
    • The LED board can easily be replaced by any other TIR6 board, any color (as far as I could check!)
    • Note that there is cooling paste between the LED board and the bracket. Make sure you replace it.
  9. Whelen Slimlighter Super-LED Teardown: 9 단계, 이미지 1/2 Whelen Slimlighter Super-LED Teardown: 9 단계, 이미지 2/2
    • All done! No more steps required :)
V3nture
회원 가입일: 10/22/10
161 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 18
전체 시간: 7,569
