주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Wireless Charging Pad 수리는 저희 서비스 설명서를 사용하십시오.
  1. Wireless Charging Pad Teardown, Removing padding to get to screws: 1 단계, 이미지 1/3 Wireless Charging Pad Teardown, Removing padding to get to screws: 1 단계, 이미지 2/3 Wireless Charging Pad Teardown, Removing padding to get to screws: 1 단계, 이미지 3/3
    • First thing to do is remove the pad that covers the screws. This is what the phone sits on when charging (on top of device).
    • Use a spudger or some other kind of flat tool you can pry under the padding with to loosen the adhesive and pry off.
    • Pry gently as you don't want to rip or tear this padding. NOTE: It is only held on with a sticky adhesive tape.
    • For an original Samsung charger, there are no screws. Insert a plastic spudger into the side where the rotation lock clip is (Circled red). use the charge port reference (Blue square) to locate the correct side. Then simply rotate the top from the bottom anti-clockwise.
  2. Wireless Charging Pad Teardown, Removing Screws: 2 단계, 이미지 1/3 Wireless Charging Pad Teardown, Removing Screws: 2 단계, 이미지 2/3 Wireless Charging Pad Teardown, Removing Screws: 2 단계, 이미지 3/3
    • Once you have removed the padding ring you will notice (4) phillip head screws.
    • Use a small screwdriver to remove these screws. (I used a #1.2 phillip head screwdriver).
    • Once the screws are removed you should be able to remove the bottom cover of the device exposing the circuit board.
  3. Wireless Charging Pad Teardown, Inside the Bottom Cover: 3 단계, 이미지 1/3 Wireless Charging Pad Teardown, Inside the Bottom Cover: 3 단계, 이미지 2/3 Wireless Charging Pad Teardown, Inside the Bottom Cover: 3 단계, 이미지 3/3
    • Once you have the bottom cover off you can access the circuit board and charging unit.
    • To access the top of the charging unit just pry away the top cover and the piece the circuit board is connected to.
  4. Wireless Charging Pad Teardown, Circuit Board Removal: 4 단계, 이미지 1/3 Wireless Charging Pad Teardown, Circuit Board Removal: 4 단계, 이미지 2/3 Wireless Charging Pad Teardown, Circuit Board Removal: 4 단계, 이미지 3/3
    • To remove circuit board: There are two clips holding the board in place (see photo 1). Using a spudger or a flat tool pry one of the clips away while lifting up on that end of the board. Once the board clears the clip the board will come out.
    • To remove charging unit: The charging unit is held in by adhesive and connected to the circuit board (see photo 3). Just pry from adhesive.
  5. Wireless Charging Pad Teardown, Make Repairs: 5 단계, 이미지 1/2 Wireless Charging Pad Teardown, Make Repairs: 5 단계, 이미지 2/2
    • Whether replacing circuit board or charging unit... Any work done here will have to be soldered.
    • The charging unit is soldered to the back of the circuit board. (see photo)
  6. Wireless Charging Pad Teardown, Put back together: 6 단계, 이미지 1/1
    • You can put back together in reverse order.
  7. Wireless Charging Pad Teardown: 7 단계, 이미지 1/1
    • No modelo EP-NG930 Samsung wireless chager (Vietnam), os parafusos da placa de circuitos ficam embaixo. É necessário retirar o adesivo emborrachado para acessar.
Bill
회원 가입일: 09/17/14
818 평판
안내서 5개 작성하였습니다
댓글 6개
If you don't like the beep, disable the speaker. If the speaker is surface mounted it can't be easily disconnected. Use a drop or two of superglue inside to silence it.
harryhouck - 답글
this is for the fake one, what about the original one? it doesnt have this screws
Diego Mello de Souza - 답글
this is NOT the genuine version
Fernando - 답글
It’s fake ditto
Eric Hiller - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 26
30일 전: 91
전체 시간: 30,299
