주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Withings Body Cardio 수리는 저희 서비스 설명서를 사용하십시오.
  1. Withings Body Cardio Teardown, Opening the scale: 1 단계, 이미지 1/3 Withings Body Cardio Teardown, Opening the scale: 1 단계, 이미지 2/3 Withings Body Cardio Teardown, Opening the scale: 1 단계, 이미지 3/3
    • Opening up the scale was not an easy task – there was a lot of double-sided tape involved.
    • The back of the scale is fastened with four Torx screws – easy enough. The entire backplate, however, is glued to the front with double-sided adhesive cushions. Removing it simply involved pulling it firmly enough to break the adhesive, but not so hard as to break the connectors. A hairdryer can help loosen the adhesive under the 4 corners.
    • With the backplate removed, you can immediately spot 4 loads cells, one in each corner.
  2. Withings Body Cardio Teardown, Main PCB: 2 단계, 이미지 1/3 Withings Body Cardio Teardown, Main PCB: 2 단계, 이미지 2/3 Withings Body Cardio Teardown, Main PCB: 2 단계, 이미지 3/3
    • ARM MCU - MK22FN1M0VLL12 (NXP)
    • weighing scale and body composition front-end IC - AFE4300 (Texas Instruments)
    • battery charging IC (including battery protection) - BQ24095 (Texas Instruments)
    • WiFi and Bluetooth radio - BCM43438 (Broadcom)
    • flash memory - MX25L3233F (Macronix)
    • op-amp - AD8544
    • connector to the USB port PCB
  3. Withings Body Cardio Teardown, Block diagram: 3 단계, 이미지 1/1
    • I’ve made an attempt to design a block diagram for the whole setup. This won’t be 100% accurate as I don’t know all the details but it will give you an idea on how the components are interlinked and work together.
November Five
회원 가입일: 08/25/16
465 평판
안내서 4개 작성하였습니다
댓글 38개
Thanks for sharing your experience, wouldn’t guess the double sided tape trick without your help.
Soon my scale will be deactivated by Nokia and was wondering what I can do with it.
ALMO - 답글
Hi please tell me what are battery dimensions. I need to order one - cause mine is already dead.
Michal - 답글
Hi, I never took note of the dimensions, it’s best you open up the scale yourself to check it out.
Since the battery is dead you’ll have to do it anyways ;)
November Five -
Thanks for the breakdown info. I'm replacing the battery as well. It's 63x50x5mm. 2100 mAh, 7.98Wh, 3.8V
I think this battery should be exactly the same:
Samsung 2100 mAh Replacement Battery for Samsung Galaxy Avant SM-G386T https://www.amazon.com/dp/B00OY9BY6W/ref...
Ryan Wills - 답글
Hi,
my battery died as well. Was the Samsung battery the correct replacement?
With best regards
MArtin
spamfilter -
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 37
30일 전: 238
전체 시간: 23,461
