주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Xbox 360 수리는 저희 서비스 설명서를 사용하십시오.
  1. Xbox 360 Power Supply Teardown, Xbox 360 Power Supply Teardown: 1 단계, 이미지 1/3 Xbox 360 Power Supply Teardown, Xbox 360 Power Supply Teardown: 1 단계, 이미지 2/3 Xbox 360 Power Supply Teardown, Xbox 360 Power Supply Teardown: 1 단계, 이미지 3/3
    • Here is an image that shows the different plugs for the different power supplies
    • The one to be tore down is Model # HP-AW175EF3. Input 100V-127V output 12V 14.2A, 5V 1A
    • Remove all four rubber feet from the bottom of the PSU. Simply flip them out with a small screwdriver or similar instrument.
  2. Xbox 360 Power Supply Teardown: 2 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 2 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 2 단계, 이미지 3/3
    • Once the rubber feet are removed, there will be another plastic cap visible.
    • Insert a small screwdriver or similar instrument
    • and just flip it out.
  3. Xbox 360 Power Supply Teardown: 3 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 3 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 3 단계, 이미지 3/3
    • With the rubber feet and the plastic cap removed, the Phillips screws will now be visible.
    • Remove all four of those
    • All the Phillips screws are 3/4 inch long. Here are the feet, caps and screws that needed to be removed.
  4. Xbox 360 Power Supply Teardown: 4 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 4 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 4 단계, 이미지 3/3
    • Use a plastic opening tool, or similar instrument, to widen the gap between the top and bottom half of the PSU.
    • Slide the opening tool along the gap will release the tabs that hold the two parts together.
    • Do the same on the opposite side of the PSU
    there is a 0% chance you will pry this open with a soft plastic tool like in the picture, even with a metal tool and a hammer is hard to get into this space between the two parts.
    Thijs van Ulden - 답글
    @thijsvanulden that is actually what I used on that power supply. I know there are some models of the PSU that are a bear to open, this one was not. I am not in the habit of making guides with fake pictures or on equipment that has precious;ly been opened. My guides will always show the tools I use (plastic opening tool, or similar instrument) and the steps I take.
    oldturkey03 -
  5. Xbox 360 Power Supply Teardown: 5 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 5 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 5 단계, 이미지 3/3
    • Once the snaps are released by the opening tool,
    • gently move the two parts apart. First at an angle,
    • then finally pull them straight apart. There is no glue or any other material that holds the PSU together.
    • Do not try to totally separate the two pieces. There is a fan wire that still needs to be disconnected.
  6. Xbox 360 Power Supply Teardown: 6 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 6 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 6 단계, 이미지 3/3
    • Here are the two parts separated and the fan wire is visible.
    • Remove the connector by
    • pulling the tab in a direction away from the connector and then pulling upwards.
    • With the fan disconnected both pieces can now be separated.
    • The first obvious thing visible is the abundant use of thermal paste. It is found on top of every heatsink and large capacitor.
  7. Xbox 360 Power Supply Teardown: 7 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 7 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 7 단계, 이미지 3/3
    • Here is the circuit board still in the bottom case.
    • Nothing holds it down, simply lift it out of the case.
    • Circuit board and case separated
    • A PDIP IC is found on this board; a Power Integrations TNY276P AC-DC converter
    Can anyone tell me the capacitor used just beside power input?
    Fawad Jabbar - 답글
  8. Xbox 360 Power Supply Teardown: 8 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 8 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 8 단계, 이미지 3/3
    • There is large EMI metal shield soldered to the PCB, that needs to be removed.
    • Use a soldering iron, flux and a desoldering wick to remove the left
    • and right solder connection.
  9. Xbox 360 Power Supply Teardown: 9 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 9 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 9 단계, 이미지 3/3
    • Remove the shield.
    • Here is the PSU circuit board without shield.
    • On the inside of the top part of the case, is a plastic (may be Kapton) tape that need to be removed. Simply pulling on it will release it.
  10. Xbox 360 Power Supply Teardown: 10 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 10 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 10 단계, 이미지 3/3
    • Here is the reason for the abundant amount of thermal paste seen earlier. All the top ends of the heatsinks as well as the capacitors make contact to this larger heatsink. The previously removed plastic sheet is an electrical insulator
    • Remove the six Phillips screws.
    • Remove the heatsink from the case. The six screws are identical in length. Underneath the heatsink is the fan
  11. Xbox 360 Power Supply Teardown: 11 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 11 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 11 단계, 이미지 3/3
    • Remove the four small Philips screws. They are 1/4 inch in length and all are identical.
    • pull the metal top out,
    • and then the fan. Dust and debris from usage are clearly visible.
  12. Xbox 360 Power Supply Teardown: 12 단계, 이미지 1/3 Xbox 360 Power Supply Teardown: 12 단계, 이미지 2/3 Xbox 360 Power Supply Teardown: 12 단계, 이미지 3/3
    • Here is the top part of the PSU, minus the heatsink and the fan.
    • The disassembly was quick and easy. Interestingly enough there are PSU's with a T10 Security screw. The next two images are from a 150W PSU. Make sure you have the right tools for the job.
  13. Xbox 360 Power Supply Teardown: 13 단계, 이미지 1/1
    • Parts that need to be checked if the PSU has failed, are
    • the fuse
    • and the thermistor.
oldturkey03
회원 가입일: 09/29/10
781,160 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
32 회원들
안내서 530개 작성하였습니다
댓글 11개
PSU fan spins up the a red light. Checked thermistor and it seems in range 8ohm at room temperature, around 5 ohm at 100c, consistent increase with cooling and decrease with heat, no equipment to test under full load. All big caps look good and test OK in circuit. Starting to think there is something else a muck here. Anybody got any thoughts?
Denis - 답글
Does the Xbox 360 slim PSU also use a 12v fan? Or does that PSU use a 5v fan?
Tech Savvy - 답글
If the termistor is gone and I meant disappear how I find what kind I need to get also the fuse can I put a higher amp one in like a 10 amp instead of a 8 ?
negrochiquitablanca - 답글
No, the amperages are set at that amount for a reason. If you use higher, the fuse may not blow in time to prevent damage to the Xbox.
Roger Murphy -
just want to know I am in the same boat. I have a X808155-005 with no light and no output. the fuse is good. Haven't checked the thermistor yet but doubt that it would be the problem. I might just buy another. in case someone fixes it, I will check back.
William Peck - 답글
Hi, from Mark in England, UK. I have a background in electronics servicing working on the old crt based analogue tv sets and vcr’s as well as pro audio and automotive and industrial electronics and I’ve got a good working 203 watt x-box psu and I want to increase the 12 volt output to about 14.4 volts so I can use it to charge big lead-acid batteries and I’ve dismantled the psu as far as removing the little sub panel inside which carries the error detection and control electronics but I’m having trouble trying to figure out which components to change in order to increase the 12 volt output as there appears to be so many feedback circuits, all made with tiny little surface mount components. And there’s three opto-couplers, presumably one for 12 volts, one for 5 volts and one for standby switching. So does anyone here have a circuit diagram (schematic) of the 203 watt psu or does anyone here know where I might be able to get one? Any help most appreciated, thanks in advance, Mark.
gfhcfg34f34g - 답글
Are there any real dangers to this thing
Damien Speed - 답글
Just like any other power supply, don’t stick your fingers into it. The caps will remain charged for a while. Discharging the capacitors will eliminate all danger.
oldturkey03 -
what is the value of the ntc1 from the DPSN-186CB-1A? thank you very much. the ntc1 is burned down maybe there is something more broken. the cooling?
dennis86 - 답글
I can find datasheet about INTEGRATED CIRCUIT cpo33wd Please more info because my charger not work properly
amontiel_vargas - 답글
where do you see the "cpo33wd"? I still have the power supply and don't mind tearing it open to find out.
oldturkey03 -
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 158
30일 전: 726
전체 시간: 106,059
