주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Xbox 360 Wireless Controller 수리는 저희 서비스 설명서를 사용하십시오.
  1. Xbox 360 Wireless Controller Teardown, Introduction: 1 단계, 이미지 1/1
    • Remove 7 screws located on the back of the controller using the TR-9 Toolbit
  2. Xbox 360 Wireless Controller Teardown, Removing Analog Sticks: 2 단계, 이미지 1/3 Xbox 360 Wireless Controller Teardown, Removing Analog Sticks: 2 단계, 이미지 2/3 Xbox 360 Wireless Controller Teardown, Removing Analog Sticks: 2 단계, 이미지 3/3
    • Then take off and replace the analog sticks if they arent functioning correctly.
  3. Xbox 360 Wireless Controller Teardown, Removing D-Pad: 3 단계, 이미지 1/1
    • Remove two screws from the D-Pad using a Phillips #0 Screwdriver, After doing so, you will see two latches underneath the screws that you just removed and you have to press the two latches at the same time to completely remove the D-Pad.
  4. Xbox 360 Wireless Controller Teardown, All of the Xbox 360 controller parts: 4 단계, 이미지 1/2 Xbox 360 Wireless Controller Teardown, All of the Xbox 360 controller parts: 4 단계, 이미지 2/2
    • If you followed these directions successfully this is what the final result should look like.
  5. Xbox 360 Wireless Controller Teardown: 5 단계, 이미지 1/1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
RareWarrior123
회원 가입일: 04/26/19
119 평판
안내서 1개 작성함
댓글 한 개
man this taredown is terrable . tr9 not t3 from the start .. .. man should just take it down and try again
Dub Lux - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 31
30일 전: 145
전체 시간: 9,075
