주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Xbox 360 Wireless Controller 수리는 저희 서비스 설명서를 사용하십시오.
  1. Xbox 360 Wireless Controller Teardown, Removing the first screws: 1 단계, 이미지 1/3 Xbox 360 Wireless Controller Teardown, Removing the first screws: 1 단계, 이미지 2/3 Xbox 360 Wireless Controller Teardown, Removing the first screws: 1 단계, 이미지 3/3
    • Place the controller face down on your working surface to allow access to rear screws.
    • Take the battery compartment out.
    • Use a TR9 bit and screwdriver to remove all 7 screws.
  2. Xbox 360 Wireless Controller Teardown, Removing the back: 2 단계, 이미지 1/2 Xbox 360 Wireless Controller Teardown, Removing the back: 2 단계, 이미지 2/2
    • Remove the rear half of the controller by pulling perpendicular to the front half.
    • The battery terminals have specific grooves that they slide in and out of.
    • If the two halves do not easily separate, you can slide a spudger along the seam and/or slightly depress the left/right triggers.
  3. Xbox 360 Wireless Controller Teardown, Removing the vibration motors: 3 단계, 이미지 1/2 Xbox 360 Wireless Controller Teardown, Removing the vibration motors: 3 단계, 이미지 2/2
    • Detach the vibration motor cable from the PCB.
    • DO NOT use the cable to remove from the PCB. You may damage the motor, connector, or PCB by pulling on the cable.
    • After detaching the vibration motor cable from the PCB, remove the vibration motor.
    • Utilize the same technique for the other vibration motor on the opposite side.
  4. Xbox 360 Wireless Controller Teardown, Removing the PCB: 4 단계, 이미지 1/2 Xbox 360 Wireless Controller Teardown, Removing the PCB: 4 단계, 이미지 2/2
    • Make sure the front half of the controller is facing towards you.
    • The PCB should simply lift out with little to no force when being held by the areas highlighted.
    • If the PCB doesn't freely lift out, apply light consistent leverage under the highlighted area.
    • Be cognizant of the components on the opposing side of the PCB.
  5. Xbox 360 Wireless Controller Teardown: 5 단계, 이미지 1/1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
  6. Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: 6 단계, 이미지 1/3 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: 6 단계, 이미지 2/3 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: 6 단계, 이미지 3/3
    • Gently peel off the conductive rubber pads to expose the backsides of the buttons
    • Remove the A, B, X, Y, Back, Start and Guide buttons. The Guide button sleeve may also be removed.
    • You can now remove the bumper assembly at the top.
  7. Xbox 360 Wireless Controller Teardown, Removing the D-Pad: 7 단계, 이미지 1/1
    • Remove the last two screws in the D-pad with a #0 Phillips screwdriver.
    • Use a pair of tweezers to squeeze the clips together and remove the D-pad.
  8. Xbox 360 Wireless Controller Teardown, End result: 8 단계, 이미지 1/1
    • And here is the final result: a completely disassembled Xbox 360 Wireless Controller.
Mart-Jan
회원 가입일: 05/26/19
305 평판
안내서 1개 작성함
댓글 3개
Excelente trabajos
RIGO NOLASCO - 답글
Very clear, helped me clean my controller. Thank you :)
Taydolf Swiftler - 답글
Hello. I just did clean one of mine that i did bye 2011. The Rumble on left end right are the opposit to this guide.
I did never disconnect them from the pcb. So ma bey its another revision or the left and right is missing.
From the back.
Small left , big right.
https://imgur.com/a/DxXdUNB
Michael Orban - 답글
댓글 쓰기
조회 통계:
24 시간 전: 27
7일 전: 172
30일 전: 863
전체 시간: 32,482
