주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Microsoft has launched a new version of its official Xbox One Wireless Controller. It has a 3.5mm stereo headset jack, which will allow most third-party gaming headsets to directly connect to the controller for the first time.
해당 분해도는 수리 안내서가 아닙니다. Xbox One Wireless Controller 1697 수리는 저희 서비스 설명서를 사용하십시오.
  1. Covert Forces model - Bowie 'Changes' look. New 3.5mm jack socket next to expansion port.
    • Covert Forces model - Bowie 'Changes' look.
    • New 3.5mm jack socket next to expansion port.
  2. Remove battery cover and battery Remove side panels using spudger Expose T9 security  screw under label
    • Remove battery cover and battery
    • Remove side panels using spudger
    • Expose T9 security screw under label
    • Remove 5 x T9 security screws from chassis
    • Remove top and bottom covers
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove 2 x T6 security screws on bottom PCB De-solder rumble pack and trigger wiring
    • Remove 2 x T6 security screws on bottom PCB
    • De-solder rumble pack and trigger wiring
  5. Thar she blows! DA7212 Dialog Semiconductor CODEC with Class G HP AMP and Class AB speaker driver.
    • Thar she blows! DA7212
    • Dialog Semiconductor CODEC with Class G HP AMP and Class AB speaker driver.
    • CODEC sits next to contact pads for 3.5mm jack socket
Bito Zapata
회원 가입일: 2015년 08월 27일
144 평판
안내서 1개 작성함
Is it possible to show the other board? Was thinking of doing a scuf-style mod to one of these... Thanks
blazeclarkebcc - 답글
Was asking this because the boards are different to the older controller. I have PCB prints of the old one, but not the new one. Thanks.
blazeclarkebcc -
Can you point me where to get schematics that you have?
Piotr Zieliński -
Anybody know where I can get the new style bumpers for this style of controller? Any help would be greatly appreciated.
Rhys Jones - 답글
The guy I buy from on ebay said they would be available at the end of January
themadmaxof07 -
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 128
30일 전: 506
전체 시간: 45,107
