주요 콘텐츠로 건너뛰기
Xbox Disassembly
필요한 것
동영상 개요
  1. Xbox Disassembly, Xbox Disassembly: 1 단계, 이미지 1/1
    • Start with your Xbox unplugged and sitting on a flat, stable surface.
  2. Xbox Disassembly: 2 단계, 이미지 1/1
    • Flip the Xbox over and pry off the rubber feet with a metal spudger.
  3. Xbox Disassembly: 3 단계, 이미지 1/2 Xbox Disassembly: 3 단계, 이미지 2/2
    • Peel back both the silver sticker and the white barcode sticker to reveal two additional screws.
  4. Xbox Disassembly: 4 단계, 이미지 1/1
    • Use a T20 Torx screwdriver to remove the four screws located under the rubber feet you just removed as well as the two screws from beneath the stickers removed in the previous step.
  5. Xbox Disassembly: 5 단계, 이미지 1/2 Xbox Disassembly: 5 단계, 이미지 2/2
    • Once the bottom shell is no longer attached, carefully turn the Xbox right-side-up and lift off the top shell.
  6. Xbox Disassembly: 6 단계, 이미지 1/2 Xbox Disassembly: 6 단계, 이미지 2/2
    • Move the grey ribbon cable out of the way in order to remove the three 3 mm screws using T10 Torx screwdriver. They are located on the upper right corner, lower right, and lower left corners of disk drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  7. Xbox Disassembly: 7 단계, 이미지 1/2 Xbox Disassembly: 7 단계, 이미지 2/2
    • Lift the hard drive storage unit out of the Xbox. It should come right out.
    • Take the power cable out of the track around the hard drive so that the unit will come out easier.
  8. Xbox Disassembly: 8 단계, 이미지 1/3 Xbox Disassembly: 8 단계, 이미지 2/3 Xbox Disassembly: 8 단계, 이미지 3/3
    • Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive.
    • Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
  9. Xbox Disassembly: 9 단계, 이미지 1/2 Xbox Disassembly: 9 단계, 이미지 2/2
    • Unplug both the ribbon cable and power cable from hard drive.
    • They are in there pretty tightly, so this may take some effort.
  10. Xbox Disassembly: 10 단계, 이미지 1/3 Xbox Disassembly: 10 단계, 이미지 2/3 Xbox Disassembly: 10 단계, 이미지 3/3
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
  11. Xbox Disassembly: 11 단계, 이미지 1/1
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
  12. Xbox Disassembly: 12 단계, 이미지 1/1
    • Unplug the multi-colored power cord from the motherboard. It can be plugged in very tight, so it may take some effort to unplug it.
  13. Xbox Disassembly: 13 단계, 이미지 1/2 Xbox Disassembly: 13 단계, 이미지 2/2
    • Using T10 Torx screwdriver, remove two 3mm screws from the power supply board.
  14. Xbox Disassembly: 14 단계, 이미지 1/2 Xbox Disassembly: 14 단계, 이미지 2/2
    • Remove the power supply and set it aside. It should lift right out.
  15. Xbox Disassembly: 15 단계, 이미지 1/2 Xbox Disassembly: 15 단계, 이미지 2/2
    • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
  16. Xbox Disassembly: 16 단계, 이미지 1/2 Xbox Disassembly: 16 단계, 이미지 2/2
    • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
    • Unplug the power cable attached to the fan.
  17. Xbox Disassembly: 17 단계, 이미지 1/1
    • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
  18. Xbox Disassembly: 18 단계, 이미지 1/1
    • Pry the plastic fan clips away from the fan base and remove the fan.
    • This may take a little effort, as the clips are pretty stiff. Beware, the fan will be filthy.
  19. Xbox Disassembly: 19 단계, 이미지 1/2 Xbox Disassembly: 19 단계, 이미지 2/2
    • Using a T10 Torx screwdriver, remove two 3mm screws from each of two controller sockets.
    • Take the sockets out by pulling back and up at the same time.
  20. Xbox Disassembly: 20 단계, 이미지 1/1
    • Congratulations, your Xbox is now completely dismembered.
결론
다른 48명이 해당 안내서를 완성하였습니다.
rmarstel
회원 가입일: 10/29/09
5,674 평판
안내서 5개 작성하였습니다
Cal Poly, Team 18-2, Maness Fall 2009 Cal Poly, Team 18-2, Maness Fall 2009 회원
CPSU-MANESS-F09S18G2
3 회원들
안내서 24개 작성하였습니다
댓글 10개
Awesomeness, thanks a lot!
godoyander - 답글
Thanks a million - perfect!
xan_lucky16 - 답글
Heatsink removal?
Matt Russell - 답글
Did a complete cleanup and refresh of my Xbox thanks to your guide, thank you :)
Mickaël STEMMER - 답글
댓글 쓰기
조회 통계:
24 시간 전: 58
7일 전: 371
30일 전: 1,876
전체 시간: 182,316
