주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Acer Aspire One 725 수리는 저희 서비스 설명서를 사용하십시오.
  1. acer aspire one 725 Teardown, This is an acer aspire one: 1 단계, 이미지 1/3 acer aspire one 725 Teardown, This is an acer aspire one: 1 단계, 이미지 2/3 acer aspire one 725 Teardown, This is an acer aspire one: 1 단계, 이미지 3/3
    • prepare you're self for a lot of screws
  2. acer aspire one 725 Teardown, Remove the battery: 2 단계, 이미지 1/3 acer aspire one 725 Teardown, Remove the battery: 2 단계, 이미지 2/3 acer aspire one 725 Teardown, Remove the battery: 2 단계, 이미지 3/3
    • on the top right corner and slide it to the right
    • It release very easily
    I am facing the problem when I start laptop it showing , undoing changes done to computer . So please guide me
    Padmakar chavan - 답글
  3. acer aspire one 725 Teardown, Getting inside the laptop: 3 단계, 이미지 1/3 acer aspire one 725 Teardown, Getting inside the laptop: 3 단계, 이미지 2/3 acer aspire one 725 Teardown, Getting inside the laptop: 3 단계, 이미지 3/3
    • There's a screw natural reaction unscrew it
    • Slide the cover right off
  4. acer aspire one 725 Teardown, Removing the ram: 4 단계, 이미지 1/3 acer aspire one 725 Teardown, Removing the ram: 4 단계, 이미지 2/3 acer aspire one 725 Teardown, Removing the ram: 4 단계, 이미지 3/3
    • Simply push these pins out and it'll come out
    • It's kinda fun to taking it out and pushing it back in
  5. acer aspire one 725 Teardown, Removing the hard drive: 5 단계, 이미지 1/3 acer aspire one 725 Teardown, Removing the hard drive: 5 단계, 이미지 2/3 acer aspire one 725 Teardown, Removing the hard drive: 5 단계, 이미지 3/3
    • More screws unscrew them
    • It might be hard to removing the hard drive so use the screwdriver to push it out
  6. acer aspire one 725 Teardown, Still removing the hard-drive: 6 단계, 이미지 1/3 acer aspire one 725 Teardown, Still removing the hard-drive: 6 단계, 이미지 2/3 acer aspire one 725 Teardown, Still removing the hard-drive: 6 단계, 이미지 3/3
    • This is what it should look like
    • You can also change the hard-drive if you want by unscrewing the metal piece
  7. acer aspire one 725 Teardown, Just a look: 7 단계, 이미지 1/1
    • to see how it looks like
  8. acer aspire one 725 Teardown, Before removing the keyboard: 8 단계, 이미지 1/2 acer aspire one 725 Teardown, Before removing the keyboard: 8 단계, 이미지 2/2
    • Please remove the black and blue strip
    • These are connected to the keyboard
    • Also unscrew all the screws keeping the panel down
  9. acer aspire one 725 Teardown, Removing the keyboard: 9 단계, 이미지 1/2 acer aspire one 725 Teardown, Removing the keyboard: 9 단계, 이미지 2/2
    • pry it open by where the battery was
    • These show the mother board
    • There are multiple screws, black screws and sliver screws
    • I labeled black screws with red. I labeled the sliver screws with yellow.
  10. acer aspire one 725 Teardown, The touch pad: 10 단계, 이미지 1/3 acer aspire one 725 Teardown, The touch pad: 10 단계, 이미지 2/3 acer aspire one 725 Teardown, The touch pad: 10 단계, 이미지 3/3
    • There is a purple strip and unhook it
    • Take off the panel that the blue and purple strip its connected to
  11. acer aspire one 725 Teardown, The key board separated: 11 단계, 이미지 1/2 acer aspire one 725 Teardown, The key board separated: 11 단계, 이미지 2/2
    • A look of the key board
    I want new key board. What is the
  12. acer aspire one 725 Teardown, So far we gone: 12 단계, 이미지 1/3 acer aspire one 725 Teardown, So far we gone: 12 단계, 이미지 2/3 acer aspire one 725 Teardown, So far we gone: 12 단계, 이미지 3/3
    • I know that we didn't take apart the mother board but this is all that
    • I hope that you find this useful
Poua Yang
회원 가입일: 11/10/16
171 평판
안내서 1개 작성함
댓글 2개
thanks !!!! a lot
alej689 - 답글
Great guide, Thanks.
Do you know if there is a lithium battery (coin shape) ? or a jumper for BIOS password resetting ?
Nico Land - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 18
전체 시간: 3,712
