주요 콘텐츠로 건너뛰기
도움말
12단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Push up on the trigger pin to remove it. These are ment to be loose fitting for easy teardown.
Once pin is out, the hammer will just slide out.
The next step is only on series 80 styles. Underneath the hammer is the safety lever that pushes up on the firing pin block in the slide when the trigger is pulled.
Remove safety lever, it will just fall out (tweezers are just for show).
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
