주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
도움말
10단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
That's it! In a surprising departure from its older sibling, this Pebble 2 turned out to not be very repairable at all.
If we had the authority of the iFixit team behind us, we would probably rate this at a 2/10.
Pebble stuck with industry-standard 22 mm watchbands, so you can still swap those out all you like!
The motherboard and first part of the screen can be removed fairly easily,
but with both the battery and the vibration motor soldered on, there won't be much swapping going on.
Since the second half of the screen is glued to the front glass, neither it nor the glass are feasibly replaceable.
Button replacements are also a no-go.
If you're looking to stay on the Pebble train as long as possible, you might want to pick up a few of these on Amazon while they're still around.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
