주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
도움말
7단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Survey says: a six-degrees-of-freedom magnetic sensor coil for tracking the position of the controller.
The intensity of the three perpendicular magnetic fields is measured to determine the position and orientation of the controller relative to the headset.
Cracking open the controller, we find the (much bigger) emitting half of the tracker, and an 8.4 Wh battery to boot.
The copper shielding sprayed into the coil housings likely protects from RF interference, while letting the magnetic field through.
Interference could explain the tracker's odd placement, and this may be a temporary solution. It's "old" tech, and will probably be worse for left-handed use.
Not pictured: we also dug up what looks like a custom-designed trackpad ringed with LEDs (for future light-tracking hardware, perhaps?).
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
