주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
9단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
This step will damage your product but is the simplest and most effective way to access the motor components/PCB as the case is plastic welded to minimise moving parts when the blender is in use.
Begin by taping the circumference of the shell above the release buttons.
Draw a line around the shell with a marker, 5mm above the two release mechanisms.
Using a hacksaw, gently slice back and forth along the line while rotating the casing, making sure to stop at the surface of the metal component inside, this is the motor.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
