주요 콘텐츠로 건너뛰기
도움말
10단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
To access the main components all that is left is to remove the bottom section that we had just cut.
This step may require a bit of force, some prying around the edges, or even heat as the section above the plastic weld may still be stuck or there may be adhesive still holding the motor to the outer casing to reduce internal vibrations.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
